naits s50b32 turbo build
nait
Update..motor out
nait
update..parts that arrived
86.5m 8.7.1 comp with forged rods
custom 6.8kg single mass flywheel
tilton tripple pack clutch
ltw seats
yellow speed coilovers
R!Yo
Staff - Social Media
Its your car man, you do with it what makes you happy! :rollsmile::rollsmile:
Really cool build if you ask me, cant wait to see it finished after the reworked motor! Can see no cent is being spared!
Happy boosting dude!:coolShake:
nait
Nikhil@TheFanatics said:
That escalated quickly :rollsmile: where did you source the rods and pistons from?
Hi nikhil. Fcp engineering. Its a european based company. They focus on performance parts for most euro cars. Search them spot on service and quality that the swedish engine builders live by.
Thank you buddy. Much appreciated support:clapper:
nait
Heres a video of a turbo s50b32 m3 that was later supercharged as the owner felt that turbo m3s were to common. This is a 9 second pass but i hear the car has run a 8 second pass with the same centirfugal setup..
nait
Parts update to wake this thread up..
new timing chain and oil pump chain, rails ect
new oem oil pump with high flow vac internals
king race series bigend and main bearings
nirvash
Awesome, that's a very impressive list of parts you've put together, I'm sure your car is going to turn out quite beastly at the end of this, can't wait to see
Prev
Administrator
Epic build in progress. Well done :clapper:
What's the plans for the suspension and brakes? The E36 Shock towers and some other bits are prone to tearing. Wont the additional power be amplifying the problem?
Hope we get to see this car at one of the local events when you are done with the build :thumbs:
nait
Thank you. Trying to source the best possible parts but with the exchange rate its taking time.:thumbdo:
For now im going to use the yellowspeed coilovers and standard brakes. Im going to reinforce all the weak points as its definitely going to cause a lot more wear with the additional power. The plan is to race the car around the country so im sure you will see it:rollsmile:
