Benji
This is the most true statement I have ever come across and a hard lesson to learnYou always want to start with the best possible example you can afford - that is always cheapest.
Regarding quality of "OE" parts, I have found roughly 50% of Lemforder parts are not made in Germany anymore. The Turkey and Malaysia parts seem fine, but the Chinese parts are of visibly poorer quality and do not come with new fasteners.
True words spoken but with the caveat that it also depends on where you want to land. For a driver quality car that you can put miles on, if you're fine with a scuffed up interior and maybe a bit of rough seat wear etc. etc. you can probably save some money. But get one mechanically sound - the bits and bobs add up very quickly on an M car. If you want perfection, you might as well just buy a collector example (but then you'll feel bad every mile you put on it!)My best advice is never to go for an example that needs "rescuing". My M5 is actually a really good starting point, and while it may seem like it needs a lot of work, this is just what they need at 24 years / 100,000km. It was the same with my E46 M3 10 years ago.
You always want to start with the best possible example you can afford - that is always cheapest. In this case, I chose a car from a long term owner who I've known my whole life, and just in general, facelift E39 M5s that are unmolested are just so incredibly rare.
Anyhow, I hope you enjoy observing the project! I'll keep things updated as they happen![]()
Well, the coolest product that Carphonics offer is where they take the factory TV module, retrofit it with Wireless Apple CarPlay, and then they also retrofit the factory satnav screen with a touchscreen. It keeps the factory navigation and software and allows you to switch to Carplay.You are doing things I didnt know were possible š»
This brings tears to the eyes. Beautiful car and meticulous work, well done sir š»Windscreen Moulding
Due to age, the windscreen rubber moulding had begun to crack. Itās actually a fairly straight forward DIY, but it can turn into a giant pain to clean the channels after removing the old one, so I had Garage808 take care of this one for me.
Work Completed
Old and Cracked Moulding
- Installed New Windscreen Moulding (Genuine BMW)
I'll update the thread with pics of the new moulding when I have access to the car again. I forgot to take some before writing this post.
Right Rear Door Lock Actuator
In Chapter 2, I took care of the lazy left rear door lock actuator, and in this chapter we took care of the right rear as it also showed evidence of slowing down. You really donāt want these to fail in the locked position, so better to get it done before that happens.
In the process, as was the case with the left side, Colin had to remove the vapour barrier and clean off all the old failing butyl sealant, so now both rear doors have reliable door locks and fully re-sealed vapour barriers. These things are simply a function of age, even with a car thats been garage kept its whole life. 25 years is 25 years!
Brake Fluid Flush
In chapter 2, I had Turner Motorsport Stainless Brake lines installed, not only at the callipers, but also specifically at the ABS module where the factory items are a fire hazard. Unfortunately, this job introduces air into the middle of the brake system and this air is notoriously difficult to bleed out on E39s. Last time I mentioned that the first attempt at bleeding was insufficient, so this time Colin must have spent several hours bleeding, including using diagnostic software to trigger the ABS pump to assist with the process. He went through 6 litres of brake fluid! Anyway, the brakes feel much better now.
Work Completed
- Brakes extensively bled
Viscous Fan & Clutch
Itās almost cliche at this point, but everyone always says to replace the viscous fan blade and clutch due to age. The reason for this is that the viscous clutch can seize, and the plastic fan blade can get brittle and in either of those cases, you could have the fan blade exploding and damaging everything on the front of the engine, including the bonnet. Not wanting to encounter that experience, I preventatively replaced them.
Work Completed
The existing fan blade that was removed from the car did not feel brittle at all, and Colin said the existing Viscous Clutch was also still fine. So, Iāve kept them as spares for the future. This was another general preventative measure.
- New Viscous Fan Blade (OE)
- New Viscous Fan Clutch (OE)
Old and New Fan and Clutch
Old ones kept as spares as they are still in very good condition
Fuel Pump and Level Sender
Not wanting to be stranded by a 20 year old, broken fuel pump, I decided to preventatively replace it. I also replaced the Right Side Fuel Level Sender as I could see it was misreading, and from some 2021 diagnostic print outs, there were also historical errors related to this part.
Usually when old BMW fuel level senders misbehave, they āover-readā the fuel level, meaning that the fuel gauge will show something like 1/4 tank when itās actually empty. In my case, it was the opposite: A full tank would have the gauge showing 9/10s.
The motorplan history of the car shows a fuel pump replacement in 2002 at just 15,000km! There was some evidence of poor dealership work, and Colin corrected all of this during this job.
Work Completed
Old, extremely dirty fuel pump with wiring bafoonery from BMW Dealer back in the day
- New Fuel Pump (OE)
- New RHS Fuel Level Sender
Cleaned up, corrected, and new pump installed
Instrument Cluster Dead Pixels
Probably the most noticeable and annoying issue on this car, and itās a very common one, was the āOBC Highā instrument cluster LCD showing dead pixels. While the car was at Garage808, I had them send it off to Combined Electronics to have this fixed. Itās something one sees every time one drives the car and just like the failed review mirror, screams āold and brokenā. Iām really glad I got this fixed@
Work Completed
- Replaced Instrument Cluster LCD
Old LCD with Dead pixels (not the best photo of how bad it really was)
Pixel Perfect Cluster
Miscellaneous
A small but noticeable detail - the right rear exterior door handle took slightly more effort to pull to open the door compared to the others. Colin adjusted it and now it feels exactly the same as all the others. Itās details like this that really matter, and youād be surprised as to how many things like these M5s have, both high and low mileage. At the risk of sounding extremely repetitive, there are a lot of age related things on these cars and if youāre most unfortunate as I am to be blessed with an eye for detail, itās hard to leave some of these things unaddressed.
Work Completed
Random Pic of the Door In Question
- Adjusted Right Rear Exterior Door Handle
Wheel Alignment
As the final step, with a fair amount of suspension work having been done to the car, a wheel alignment was in order. Tiger Wheel & Tyre Willowbridge is managed by a former (or perhaps still current) member of BMWFanatics, and they were very good at taking their time to set the alignment properly. The car drives great, and I have to say, the comfort and handling of the E39 platform is just so wonderful. Itās such a nice car to drive!
Note the Improved Bumper Fitment and Exhaust Alignment after the diff job which involved removing the rear bumper and exhaust
Special Thanks to Garage808
I feel it is important to give a special mention and big thank you to Garage808. Despite this car being un-abused and garage kept itās old life, it is at an age where almost every job takes much longer than one would expect. Many original parts are seized or very unwilling to cooperate and in reality, the jobs take much longer than what is justifiably quoted and invoiced for.
Colin was careful to take his time to make sure the jobs werenāt rushed, he also put in a lot of extra time to do little bits of cleaning and making sure that little details are right. For the most part, this car is very original, but here and there are some past sins from BMW dealer workmanship.
All in all, the car was there for about 5 weeks for this booking and they probably did about a week of free labour with all the extra time it took to complete each job. They did this because they recognise that I want things done properly and carefully, and equally they care about being a part of a restoration projects of a special car like this one They agree that this particular example is a rare, un-abused example and that itās worth the investment that I am putting into it. I am very grateful for this, so thank you to Colin and Adele who have been great to work with on this project, and will continue to be my primary partner in this project when it comes to mechanical work and maintenance.
With Garage808, there's never a doubt that your parts were replaced. They always return the old parts very neatly packed. It's a nice touch. This wasn't even everything, I just put out the big items that were replaced!
Conclusion
Finally, after an eye-watering amount of money, the car is mechanically up-to-date for the most part. A project like this is never done, and there are still more things to be addressed in upcoming chapters. So stay tuned and until then, stay well and drive safe!
On a side, note, how ridiculously expensive is the front diff mount! Only available at BMW as well...
Amazing work @AdiS , this makes one understand the current asking prices on some of these if a meticulous example like yours gets pampered in this manner.Windscreen Moulding
Work Completed
Brake Fluid Flush
Work Completed
Work Completed
Work Completed
Work Completed
Miscellaneous
Work Completed
Wheel Alignment
Colin was careful to take his time to make sure the jobs werenāt rushed, he also put in a lot of extra time to do lots of cleaning and making sure that little details are right. For the most part, this car is very original, but here and there are some past sins from BMW dealer workmanship that needed correcting.
All in all, the car was there for about 5 weeks for this booking and they probably did about a week of free labour with all the extra time it took to complete each job. They did this because they recognise that I want things done properly and carefully, and equally they care about being a part of a restoration project of a special car like this one They agree that this particular example is a rare, un-abused example and that itās worth the investment that I am putting into it. I am very grateful for this, so thank you to Colin and Adele who have been great to work with on this project, and will continue to be my primary partner in this project when it comes to mechanical work and maintenance.
Conclusion
That isnt bad at all, I seem to recall something closer to R2800Thanks very much! The front diff mount was about R1250 from BMW. Not too bad IMO.
