My E92 335i
Pri
Congratulations! thanks for the pics keep them coming for us pic whores :rollsmile:
ShaunB
Thank you sir, ill will surely upload plenty more pictures in the time to come.
Had lots planned for the weekend but did not get time for anything else.
ShaunB
Some updates;
You guys can see my dent removal Thread here;
http://www.bmwfanatics.co.za/showthread.php?tid=67570
Donnie's Sexy car;
The master at work;
On to the mods, removed my window trims to paint them.
Its not a hard job but you need to take your time and be patient.
Tools of the trade.
Trims and kidney grills removed.
Trims and grill surrounds were cleaned and wiped down with acetone, masked up and then painted.
I will leave it till tomorrow to harden and cure, then refit.
ShaunB
AshG108 said:
Waars die prentjies Chom?
Did you not fit the grills and trims back?
Hey chom.
I left the goods for an extra day to cure cause of the cold weather, it is Epoxy paint so it takes a bit longer to harden.
ShaunB
Friday Night I got all the trimmings etc fitted back.
Cleaned all the rubbers and crevices.
Grill got a make-over too.
Before
After
Before
After
Grill
Trimmings
ShaunB
Saturday night I wanted to set the car alight.
On the way to a car event it left us stranded next to the road, waterpump packed up, a common problem on the N54 motors, although expensive repair, and only having done 400km with the car I was quite upset.
Sunday morning I got started on the car.
Was shocked at the water that was drained.
After about 3 hours of wrenching the Thermostat and Waterpump was out.
In the process of sourcing a new one.
After this was done I enjoyed a few beverages and moved on to the calipers.
Before
Product Used
After
Will do the rears in the week.
AshG108
hey, cabbie looks leaker dude...grills and trims really came out nice. Caliber is fresh ya!
Nicely done Shaun!
ShaunB
New OEM parts collected last night.
Waterpump and thermostat.
Started assembling last night but the one pipe was a real Zuma, so need to remove pump again to connect the pipe first, will hopefully be up and running by tonight.
