Riaad's 330d
momo1
Yep, hard to go back once you get used to having AA or CP, and it really does make the car feel modern (not that its that old in the first place)
Get you, il probably needs some help with the tv mode , does this needs to have a factory module or can you add it using bimmercode?
Riaad
Events Organiser
Tv mode is a requirement only for Mr12volt units (afaik). No hardware is needed, just enable via Bimmercode.
If you happen to have the TV module installed, this will need to be uninstalled for the Mr12volt unit to work.
