83000km and the bottom end went? That's hard news to handle - sorry bud!Life happens. Can't wait to get her back and carry on with the build.
Serviced at BMW, 5w30 oil. Mileage is 83000kms....
Sent from my VOG-L09 using Tapatalk
Really unfortunate considering the car has low mileage and its not a common issue with the N54. I've had two BMW specialists advise that the N54 should use 10W60 oil in our climate.Life happens. Can't wait to get her back and carry on with the build.
5w40 shell helix ultra is brilliant.Really unfortunate considering the car has low mileage and its not a common issue with the N54. I've had two BMW specialists advise that the N54 should use 10W60 oil in our climate.
I looked into this as well but it isn't a great idea because 90% of engine wear happens on first start up. Due to 10w60 being so thick and the n54 engine not being designed for that viscosity oil, the oil cannot get through all the oil gulley's fast enough on start up so it would actually cause premature wear. If you had a way to heat up the oil first like F1 cars then it would be a different story. 5w40 is perfect as @FiRi@Rennzport stated above. I have been using that in my car since I got it back in 2017, I change my oil every 3 - 5k and when I do I flush the engine out a few times first. It's a process but in the long run on a modified car it makes logical sense to me.Really unfortunate considering the car has low mileage and its not a common issue with the N54. I've had two BMW specialists advise that the N54 should use 10W60 oil in our climate.
Thanks for the links! I looked at this option but it said the seller doesn't shop to SA? Unless I looked at a different seller selling the same actuators.Why don’t you consider replacing both actuators since seeing you have already had this issue before ?
RHD Right & Left Twin Turbo Wastegate Actuator / BMW N54B30 135i 335i TD03L | eBay
Find many great new & used options and get the best deals for RHD Right & Left Twin Turbo Wastegate Actuator / BMW N54B30 135i 335i TD03L at the best online prices at eBay! Free shipping for many products!www.ebay.com
Mamba offers both front and rear and if you really want to future proof , you can get their wastegate anti rattle kit also.
SUS310 Turbo Wastegate Rattle Flapper Arms Rebuild Kit for BMW N54 135i 335i 535 | eBay
2 x SUS310 Flapper Arms. 2 x SUS310 Flapper Bushings. 4 x SUS310 Flapper Tabs. BMW N54 135i 335i 535i Twin TD03 Turbo Wastegate Rattle Flapper Repair Rebuild Kit. 09.2006 225KW 306HP N54 B30 A. 09.2007 225KW 306HP N54 B30 A.www.ebay.com
You know what they say … in for a penny , in for a pound
Or if you really have an itch that needs to be scratched
Heavy Duty Turbo Repair Kit For BMW N54 335i 535i 735i TD03L4-10T (Cast Wheel) | eBay
Find many great new & used options and get the best deals for Heavy Duty Turbo Repair Kit For BMW N54 335i 535i 735i TD03L4-10T (Cast Wheel) at the best online prices at eBay! Free shipping for many products!www.ebay.com
I have the Mamba kit done on my turbos, Justin brought in the kit for me and I had Gabby at Fastec do the engineering and fitment on my turbos. They have held up seriously well for a long time now. That mamba kit is proper quality! And Gabby’s work on the turbos is second to none!Thanks for the links! I looked at this option but it said the seller doesn't shop to SA? Unless I looked at a different seller selling the same actuators.
I'll take another look. Definitely would make sense to change both.
Ordered new actuators and the wastegate rattle kit from MamabtekI have the Mamba kit done on my turbos, Justin brought in the kit for me and I had Gabby at Fastec do the engineering and fitment on my turbos. They have held up seriously well for a long time now. That mamba kit is proper quality! And Gabby’s work on the turbos is second to none!
Thanks for allowing me to nag you with questionsCongrats bro, glad they came quickly.
Gaby will master those turbos and that car will be hoofing again...
.Thanks bud. Collected the turbos from Fastec today. Taking them to Solankis to be fitted tomorrow. Final stretch till she's back home!All the best with this @YasserIsmail , hope you get this back on the road and back to boosting soon!
