My 1969 2002
Bugger
ST,bring a boat,some oars,a rain coat,a life jacket,and whatever else you can find that is useful in water.....maybe some scuba gear....:fencelook:
Jandre,Please let me know when I can come and have a look! Would love to see this little motor.
J
Jandre
herr bmw said:
ok now i have seen your 2002,lucky bugger:rollsmile:
when in 69 was it built?
and please keep us updated:thumbs:
It is an early 1969 car. Was delivered to the BMW dealer in Kenya on 20 March 1969, So I would guess around Jan/ Feb 1969 or so.
Bugger, will keep you posted bud.
Sabre Tooth, you better make a plan my man.
herr bmw
ChefDJ said:
herr bmw said:
i need to see this car,nearly the same birthday as me,born feb 1969:rollsmile::thumbs:
So the car is a fossil? :slow:
i cant beleive you just insulted the commander in chiefs classic car like that:nonono:
i think you should be banned:fencelook::rollsmile:
for at least a week:roflol:
ChefDJ
Time for an update Sir Commander in Chief :idea:
I saw the photo of you towing the 2002 to the panelbeaters :rollsmile:
J
Jandre
That is correct.
Loaded her onto a flat bed trailer, and off to the panel beaters today.
They will start on her during next week, so i will update this thread as they go along.
zaleonardz
Only tip I can give you is regular frequant visits to say "Hi"
I have at the moment undertaken not to do more then one respray project at a time,
Reason being is that this is so much work, that I put one guy on it, and only he works on it.
Believe me when I say its far easier to control that way,
WHat folks dont realize is that there is probably 150 hours that goes into preperation for a respray.
Yes its semi skilled labour, but in order to get it right, you kinda need to get the guy doing the work to "love the car" he is busy working on, and as such, I actually offer a small bonus to the guy doing the prep.
It only takes an hour to hour and a half to actually spray the car, but bucket loads of preperation.
So Jandre,
1. Frequant visits, dont mind if progress is slow, or appears slow, but just as long as its moving bit by bit, and you can actually see results.
2. You want on a classic, to see that the guys put out seperate parts compartments for your car, and that all your parts are in there, and kept together, particularly beadings and clips.
3. Ask them to call you during stages.
3.1. When the car is stripped, and make sure they took out all of the parts that could be oversprayed.
3.2 When they have done the body work, and the filler has been sanded, inspect the quality of the sanding job.
3.3 Phone once they have put on the first couple of coats of MS Primer, inspect the primer, in the sense of if area's have got primer on it, you know it has to be painted,
3.4 Go and inspect the car once the primer has been flatted, look for inperfections, if your base is wrong, your final color will be too.
3.5 If the panel shop does not want to allow you all this time spent on the vehicle find another.
Hehehe, and on the resprays, I have a secret project that I AM FINALLY busy with...
Good luck Jandre, and phone if I can assist with anything..
