Weather & Hail Warnings
zaleonardz
Chef, that 7 is beyond economical repair. :(
The DME sits in the front right corner of the engine bay, reason being its water cooled, and has a cooling line that is shared with the water system of the engine, pumping coolant through it.
It did not survive the accident, second hand DME's are scarce, and no ways im going to the agents.
I am also not spending another 5k to have it repaired.
Cut chop bye bye... that was the plan...
I can pick up a 750 for under 400k if you bargain, it does not help i spend 250k in fixing this one of mine, im just gonna go and buy one....
Ralf*
A mature thunderstorm has appeared in the Potchefstroom area, and its movement trend is towards Gauteng.
the fact that it has deep colour contours means there is a possibility of hail within it already
[/img]
Ralf*
maximus said:
Was it an adolescent thunderstorm before it turned mature? :) :mmm:
nope...the correct meteorological term is developing....then mature....then dissipating
anyway, its growing and getting closer as well
