True bud aint bad. Hopefully after replacing the thermostats it increases even more.Spannie said:11.5km/l in traffic isn't bad. I get around the same. Open road I get 17km/l+
Sent from my SM-G930F using Tapatalk
Will do, it all comes down to driving style but im happy if i get 15k out of a set, thats like 1 set a year and half for me. Not too fased as long as the brakes stop lol. I mainly drove to work and back in stop en go traffic and weekends use the wifes car. Textar pads at bmw after 20% discount came in around R1700 which is crazy...but textar is a proper pad.FerdiBotha said:Funny, @SubLoaded apparently only got 15 000km out of his Surebrake pads. Maybe it was a bad batch. (Link to post - https://www.bmwfanatics.co.za/showthread.php?tid=83750&page=5)
Let us know how they are :thumbs:
Spannie said:I need to do disks on my 320d. What size are your rotors? I assume the 1 series and 3 series use the same calipers and pads?
Cornel said:Spannie said:I need to do disks on my 320d. What size are your rotors? I assume the 1 series and 3 series use the same calipers and pads?
There’s a 300mm and 312mm version.
So you’ll need to messure and see what size you have
Stompie said:Drove to work this morning and the pads feel good, pretty much feels the same as what i took out.
Car definitely has more power, torque is better and revs pick up quick when accelerating. Engine is much quieter and the car over all just drives 100 times better than before.
Monitored the temps all the way to work and got up to 87deg fairly quick and stayed between 87/88 degrees so all is good.
I disconnected my EGR vacuum yesterday and blocked the pipes off and no error codes have popped up yet. I am however getting that weird noise when the actuator for the EGR comes on so will unplug it and see if i get an error, if i dont then ill be sourcing a EGR blank off kit later.
Car pulls like a train again! So happy!
Will be replacing diesel filter and washing the gearbox soon as i bought a new 2ton trolley jack this weekend, autozone had a great special.
Cheers guys!
zaheer said:Great to hear that she's back in good health again. Disconnect the EGR plug and be done!
You can check your size on realoem with your vinSpannie said:I need to do disks on my 320d. What size are your rotors? I assume the 1 series and 3 series use the same calipers and pads?
