Yeah will get a billet depending on price. Hopefully i can get the turbo sorted month end with either a replacment or refurbing this one, all depends on pricing. But dont see why i need to replace this turbo if shaft play is non existent, so will just get wheel replaced.Spannie said:Yeah get a billet wheel, should see nice gains when you load software.
Sent from my SM-G930F using Tapatalk
Stompie said:From what i read up, if there is no shaft play then you can just replace the compressor wheel. Will have a chat to gabby this week and see what he says. Should be cheaper than a replacement turbo.
Sent from my HUAWEI VNS-L31 using Tapatalk
Captain_Stealth said:Don’t replace, upgrade
Captain_Stealth said:Isn’t that consumption high for a diesel car ?
Spannie said:Autozone sounds dodgy? Only place I'd take it is Gaby from Fastec, then you know your turbo will work. Turbo's need to be very well balanced
FerdiBotha said:Your turbo should be the Garrett GT1749V
You can pick up a brand new one from Turbo Direct for around R13k, but that will be quite a bit more than just rebuilding the existing turbo.
Cornel said:Stompie just let Gaby rebuild it with billet wheel.
