So since i got the BM, the flywheel was making the common rattling noise and then also the occasional Judder which got very bad after a little bit of Sandton traffic.
For the past 6 months after one morning, as i depressed the clutch it would make this GRRRRRR noise when the pedal is down on the floor and you could feel it on the pedal as if the thurst bearing was pressing against the pressure plate and this started to become worse and worse.
The previous clutch was replaced by BMW under warranty at around 60k on the clocks if memory serves me correct. The car is now on 198k on the clocks so not too bad and still had no slipping.
Anyways, The car was booked in at Yosh @ Darkartz Performance today and the clutch and DMF was replaced with a LUK kit.
You can see the rubbing marks on the pressure plate as well as the one spring that seems to have half unclipped and was probably what was causing the GRRRRR noise.
Im yet to fetch the car but Yosh took the car for a test drive and bed in the clutch and confirmed the car drives like it should again!
First time in almost 3 years of owninng the BM i will drive it with a clutch as it should be
UPDATE to follow after i fetched her at 2pm.
