Dean M3
Hi Gents
As requested
Over last 2 years i have been busy restoring my e30 , the car was stripped of every bolt and nut and the body was taken down to bare metal so i could treat and repair every bit of rust found
It was then coated with epoxy primer before being prepared for the brilliant red paint work and the treated to a whole lot of underbody sealant and cavity wax
Once the body was complete it was then time for the motor which i opted for a complete S54 motor , gearbox and ECU
The motor was then opened up and bearings were checked although still in good spec i decided to put in a new set of agents bearing for peace of mind
My plan was not to build a race car but something that i could i jump in with my wife and kid and drive to anywhere without the thought of having and issue with it
I had to make sure the cooling system was up to the task so i used the E46 M3 radiator, along with fan control unit so the ECU can control it just the way it does in E46 , i also made sure i got the A/C to work
The car is such a pleasure to drive with plenty of power , i feel that the s54 is the best suited engine for the e30
Below are some pics of the finished product
Feel free to comment/criticize
Sent from my SM-G988B using Tapatalk
As requested
