My first BMW E82 135i
Vinnige Fanie
Decided to check rod bearings while we had the subframe off to do the turbo. I think it's safe to say these need replacing. They have lasted 3 years and did about 2 seasons of racing.
Toying with the idea of going 10w60 to try help oil temps. And also not sure on if it's better to change oil after every event vs using Motul 300v and doing 4-6 races on that oil.
Vinnige Fanie
So a few things were needed for Kyalami.
Added a oil cooler to the mix to help with temps.
Notched the shock towers to be able to dial in more camber.
Did some DIY brake ducting to try help with the brake fluid going off and causing squishy pedal feel.
Waiting on the matching Endless rear pads still, Hopefully before Friday.
Went more aggressive on the tune in the hope to get a bit more speed. Unfortunately this turbo doesn't seem to work well with the pwg actuator it's like it can't bleed enough fast enough for the car to be happy.
Planning on just getting a bigger single turbo going to hopefully solve my power problems.
Vinnige Fanie
Kyalami done and dusted.
I expected it to be taxing due to it being over an entire weekend, But damn was I mistaken.
Ran into some unexpected issues with moving the oil cooler up top.... The water temps got too high and the car went into a protective mode which cuts all boost for a bit. Great for a reliable daily, Less Idea when you're chasing a lap time.
So after fiddling with the file ( Not my best Choice tbh) the car was actually even worse. On Saturday I managed my PB of 2:05.6 and my closest competitor was doing 2:06 at the time.
We tried a few things that didn't work and it kept going into limp mode, After a few changes we got it to work right but bow the car felt lazy and a bit weaker than the day before.
The main issue I was fighting now was heat management, I could do 1 lap before the oil and water temps got too high and the car would enter the protective mode again.
Our sessions worked out that your PB enters you into a shootout and that lap time determines where you finish for the day.
I knew I had to give it everything if I had any chance of taking my nemesis. I went too deep into sunset and lost time but managed to edge out the win with 90ms.
It really goes to show how close the competition is in this time attack format.
Below is onboard of my fastest lap.
Vinnige Fanie
So I added some additional upgrades since Kyalami.
Rebuilt my brakes, Added some ductwork for to improve cooling.
Opted for some H&R anti roll bars to try improve cornering.
Also added a Lithium battery from ATS to try save some weight, I also went straight pipe to save an additional amount of weight.
All in all I believe I have taken out almost 100kg from stock on this car.
This weekend was Red star CCW, I was a tad worried as I haven't driven that way in a couple of years but managed to take the win right at the end. The battle between myself and another competitor is close.
Here is my Video from the fastest lap of the day.
Next up Formula K
Benji
Looking good! Have you resolved your cooling issues now?
Have you done empirical measurements of the bonnet vents with wool tufts? They can actually increase under bonnet temps when they are in the wrong location
2.06 around Kylami is fast, I dont think I got much below 2.20 wit the Z4
Vinnige Fanie
So our last event for the year was at Formula K
With it being a go kart track I knew it would come down to the cornering more-so than the power of some of the other cars.
Initially session 1 I was slower than the competition, Then I made some suspension changes and the car felt a bit more stable and the times started to come down.
Halfway through the day the rain started and a decision was made to cut the day short.
I managed a 1:22.146 which gave me 9th overall. With the best time being a 1:18.217
I did manage to win my class for the day and took P1 for the championship for 2025 in RWD.
Was alot of work and improvement to get here, I'm however leaning towards going towards a full stripped out racecar and entering Bmw club series.
I also have a friend who might have a big turbo kit for me so I can try get to my 350-380kw goal.
Vinnige Fanie
So this car has started to move on to the next step of going faster.
Full cage and stripping as much weight as possible.
