Insane ๐, are the vitours doing u good with grip or would u still stick to the eagle f1s?Update - 233 9xx km - Ferric Grey 437m's
Been wanting a set of these for a long time, but finding a set in Ferric Grey proved quite difficult. When the opportunity arose, I had to grab them.
Fitted them on 19 August and Iโm absolutely loving the look. They need some minor TLC, but nothing a refurb wonโt sort out down the line.
The set came with Vitours:
235/35/19 - Front
275/30/19 - Rear
I've read that the rears might rub with the 275's but all seems fine with me so far over the approximate 200km's of mixed driving that I've done. Perhaps I'll change to 265's if I get any rubbing with passengers
The pictures really donโt do them justice.
Careful now, you are single handedly keeping the value of 330d high.Update - 236 500 km - Maintenance
With age and mileage starting to catch up with the 2015 330d, there were a few things Iโd been wanting to get done on the car
As luck would have it, something always seemed to come up and put the maintenance on hold
Eventually, I bit the bullet, dropped the car off at @Clint@MMS AUTO on Sunday, and let him work his magic
The following was replaced and serviced:
These updates, together with the previous battery, coilover and engine mount replacements, mean the car is now pretty much sorted from a maintenance perspective
- Front upper and lower control arms, tie rods and steering rack boot kits
- Propshaft flex disc (guibo)
- A/C condenser
- Motul DOT 5.1 brake fluid
- Gearbox service kit and Motul ATF fluid
- Handbrake bracket
- OEM BMW turbo downpipe clamp
- Smoke test
The only remaining item Clint recommended addressing is the water pump
I've also fitted a fresh set of Vitours. Looking forward to seeing how they perform, especially given the reviews
Slowly but surely, getting the 330d back to where it should be๐
- 234 370 km - 2 x 265/30/19 - Vitour Formula Spec Z
- 236 400 km - 2 x 235/35/19 - Vitour Formula Spec Z
Hey Anees.
Car is looking great.
Just a question can we run the std run flat set up on these rims.
225x40x19
255x35x19
I am also looking at getting these wheels for my 330d
Thanks BrotherHi bro
I have seen guys on bimmerpost run the 225/255 setup but that's with non runflats and stretch
I don't think the runflats will be able to stretch
Ideally I would say 235/265 is the minimum to run safely
100%Hi bro
Spotted you on Friday. Your car is a looker!![]()
