M Performance Power Kit for a F30 340i - Is is worth it?
KADE_M135i
Quick///M said:
HitokiriZed said:
Quick///M said:
M240i and 140i are under rated from factory. If they are neck and neck with the M2 on rollings runs and sometimes edging away then you can guess what they make stock :smilebounce:
For the 440i this kit is a no brainer if you want to keep the plan
Its important to not generalise. :eek:mgwaiting:
I raced a modded m140i with my stock M2 and was neck and neck with it. I believe up top an M2 would be ahead.
Mx40i's and Mx35i's are great cars - why must comparisons be drawn against M cars?
These are simply too different in terms of purpose and delivery to be fair.
Apologies for the derail.
I am not generalising, what I said is based on fact. Its no mystery that some modded cars don't respond to certain mods. I have sat in a M2 vs a stock m240i the results were the two cars were dead even. Fact! The cars also making near identical power on the same dyno's (kar). Point in case see link below
https://f87.bimmerpost.com/forums/showthread.php?t=1336535
The cars are indeed different they are not the same. Now with the M2 comp pack BMW will close the gap between the M140i and M240i drastically.
What mods did the M140i have? i raced an M2 with my M135i we both had same mods. i ran away from him from 100 all the way upuntil 250. seemed weaker on top more than anything...
HitokiriZed
JB4, Intake and WMI.
Your car does seem like a monster - 296wkW and 692Nm is no joke.(What mods do you have?)
I owned a modded M235i (which made 281.5wkW and 579Nm) before getting my M2, and in my experience the M2 (even with less power) is a lot livelier. I figured the LSD and suspension difference (even though my M235i did have the M adaptive suspension) enables the car to deliver power to the ground more readily and easily.
Well done on your race.
KADE_M135i
jb4, Downpipe, charge pipe and meth stage 2 plus DV+... normal stuff. i know the M2 is livelier in terms of tale happy :smilebounce:
problem is the M2 is geared up for 0-100 and over 100 the M240i and M140i beat the M2. Stock VS Stock.
  • TRACKER CERTIFICATE.pdf
HitokiriZed
My M235i was also rather tail happy, the M2 is much more controlled.
Its not really a problem - I assure you :smilebounce: - and as I mentioned I don't believe the x40i's will outrun the M2 at top. This is my opinion and experience. Happy to agree yours was different.
FerdiBotha
Here are results as tested at Gerotek. Admittedly these results may differ on the road, but in this case the M240i sure is quicker up top in terms of trap speeds. Obviously the M2 has a higher speed limiter.
Kimeran
Based on those figures, the MPPK is worth roughly 0.3 seconds on the 400m? :thumbs:
