922-ZN said:
Crash_Nemesis said:
Cool thanks, that means you not even tickling your motor yet with 4Psi(once you have the correct pulley), can't wait for results:thumbs:
Yeah man... The engine is built for boost and we not even scratching the surface.
It sucks that we need to make the charger spin faster to create the boost required, this will increase intake temps somewhat. Vortech chargers run very cool compared to roots chargers and don't need to be intercooled until they are at a certain RPM range. We haven't reached that range yet, but we will suffer some performance loss with heat soak.
Things we are going to be doing soon are water meth injection, and looking at doing the intercooler. We will need to run a 8-9psi wheel to get 4-5psi up here. More stress on the supercharger but it should be fine. The charger can run up to 17psi @ 53000rpm. I think the combination of running +-4psi with a 3:91 diff will be awesome for now.
Regarding the intercooler installation. When I say there is little to no room in there, I mean it. I have no idea how ESS and Active fit those intercooler pipes.
With that being said, I tested the car again last night, and just to confirm, only when in 4th gear at 7500rpm do I see 1psi on the boost gauge.
(have to do very naughty speeds to see this).
I'm thinking of taking the car for a dyno run to get a base figure and we start moving up from there.
