e90 330d wont clear error codes
andréroos
Hi there i have a bmw e90 330d 2007 model a while ago my computer box did get water then it blown the fuse at the battery after i fix that the car was fine but now it wont clear this faults and i can feel its under power now.
as far as i know i googled and the one fault code it throws out is throttle valve actuator control but this model does not have it? i cant seem to find it as its supposed to be by the intake manifold and then it trows out a few codes to do with the exuast temperature sensor and back presure please help i do use ista d but im stil new to the system also i did try to clear the faults and its just keep coming back instantly i did tried ecu places to test it but as soon as i say it got water damaged they so no sorry need to buy a new or second hand one without even testing it i believe its just something small if it is the ecu but yes please let me know what do you guys think thank you in advance Andrè
