SP33DYV said:As far as I know, this will just take it to 3.0? In other words, use the 330i crank, con-rods and pistons. You'll probably need to swap the injectors and MAF as well. I think the head on the 330i and 325i is exactly the same. I am talking about the M54B25 and M54B30. I might also be completely wrong.:rollsmile:
Gizmo said:To make it a 3.0lt you need all these parts from a 330i/530i. Crank, rods, pistons, intake cam, intake manifold, injectors, throttle body, intake pipes, maf and upper section of airbox.
Unless you can get all of it for really cheap then you may as well buy a complete 330i motor.
Brucet said:Those are both inter esting ideas and maybe worth a try.
Reason I'm thinking stroker is everytime anyone asks about modding a 325i on this or any other forums they are shot down and told why don't you buy a 330 or M3 blah blah blah.....
I can tell you, its hard to find a clean one of either model and that is half the reason I'm thinking of modding what I have as I know what I have.
moranor@axis said:there is a 323i in Aus with sherick cams making 180kw(157wkw) 310Nm(269wNm)
i think the 330i cam might just give a good gain with the right tune :rollsmile:
osiris said:NOS Kit.....Problem solved!
