Yes, Both right. using half of 15% as altitude loss and ~18% tranny loss I also get near 24% for total loss (fly->wheel->altitude) and assuming 1bar boost.P1000 said:Crash_Nemesis said:Just did some comparison numbers...
133kw on the wheels at the reef is effectively 191kw on the fly. According to this converter I have on my iPad. That includes the 24% loss at reef altitude. Or am I wrong here?
Pics to come soon.
Loss at the reef is at most 15%, but effectively it would be less than that if your charge pressure is regulated. If you are boosting 1 bar, it is half that...
moranor said:crash i think your calculations are wrong the kit makes just over 200kw on 0.6 bar there is no way it will make 190kw on 0.3... but i cant wait to see your dyno graphs :rollsmile:
Gizmo said:Don't forget, the power loss is higher for N/A cars (around 17% @ reef level). Supercharged or turbocharged cars compensate for the altitude and don't lose as much power (around 10-12% @ reef level). Even a little bit of boost @ reef level makes good gains, when I bolted an eaton charger to the 316i engine @ 0.1bar it made a big difference!!
My calculation is: 133wkw X 1.17 for 17% drivetrain loss = 155kw on the flywheel @ reef level. Add 12% to get 173.6kw on the flywheel @ sea level.
Now lets see those graphs because its the torque I wanna see.
moranor said:superchargers normally use a bypass valve to regulate pressure its normally vacuum actuated im not sure how it will adapt to ambient pressure differences if it does then that would be how it can lose less...
Not unless he upgrades his brakes first!sidewayz said:crash, looks like we need a day on the track
To be honest Im not sure about superchargers and altitude, I just know that the power doesn't drop off as much as 17%.killua said:Sorry for the stupid question, I have zero experience with these things, but how does a super-charger compensate for altitude? AFAIK the boost will decrease with altitude because its not like the gearing to the engine is increased. Except if there is a waste gate type of device at the intake which would regulate the pressure, and the supercharger is set up to have more boost than is needed? If there is no such thing, the loss for supercharger should be the same as NA?
