Shaheenem
Been looking for an E39 530D MSport for almost 8-9 years. Everytime one comes up for sale (They dont come up very often), it just doesnt pan out.
This particular car came up on one of the forum threads. Oddly enough, i actually knew the seller but for some reason when he posted the car on marketplace, he chose to hide the advert from friends on facebook so i didnt see the advert until someone posted it on the forum.
Anyway, got into contact with the seller and had a friend check it out for me as the car was in Cape Town. There were a lot of other interested buyers so made an offer on the spot and asked him to drop if off at one of my friends places until i get the transport arrange to get it back to JHB.
Arrived at my friends workshop in Cape Town.
Car needed a lot of work. Lots of dents on the body, a very nasty oil leak from the rear main seal, a diesel leak from the HPFP, aircon not working etc, etc.
Finally managed to get the transport arranged but when my friend went to drop it off at the depot, the radiator burst. Car had to be towed back to his place to replace the radiator.
Second attempt to get it to the depot, they rejected the car as it had a major oil leak. Again, back to his place to do a temp fix.
On the third attempt, we finally managed to get it loaded and sent up to JHB.
Finally back at my workshop in JHB.
First thing to sort out was the oil leak. Gearbox stripped and rear main seal replaced.
Then i noticed a diesel leak from the HPFP.
HPFP removed and sent in to get reconditioned with new seals etc.
Car was also not boosting correctly, so turbo came off, sent in to get reconditioned. New gasket etc installed and finally she was boosting again.
Had to redo all the vacuum lines as well going to the boost control valve, turbo actuator, EGR etc
Replaced all coolant hoses, EGR thermostat and carried out a service on the engine.
Installed an EGR delete kit at the same time.
Drivers window switch was also not working or would work intermittently. First tested wiring as some say its common for the wiring in the door to get brittle but all wiring tested fine. Eventually got a replacement window switch and it solved the issue.
Next was to tackle the aircon issue.
First noticed that the interior fan didnt work.
FSU needed to be replaced as well so that was first step. Replaced it and the interior fan started working again.
Then i noticed the aircon fan didnt switch on at all even when activating it with a diagnostics machine.
Spent countless hours tracing wires, testing replacement fans. Even got a brand new fan but still didnt activate.
Eventually had a look at the ECU connectors and found water had gotten into it and had a lot of corrosion around the pins.
I suspected that the aux fan driver must have failed on the ecu as all the wiring checked out.
Ordered a replacement ECU and waited for it to arrive.
In the meantime while waiting for the ECU i sent the car in to my panelbeater to get the body work sorted out.
Had the front bumper, rear bumper, side sill, rear quarter and a couple of other things done on it.
Also had the original style 32 wheels refurbished and a fresh set of tyres fitted.
While the car was still at the panelbeater, the replacement ECU came in and i immediately took it to test on the car. Plugged it in and activated the fan with the diagnostics and it worked! Success!
So cloned my old ECU onto the replacement and that was done. Had the aircon regassed and working flawlessly again.
After that it went to my upholsterer to sort out the drivers seat bolster, new headliner and parcel tray recover and also did the steering wheel with M stitching.
While they were busy with the interior, I removed the headlights and sent them to get the lenses replaced together with the headlight adjusters which are a common issue on the E39 headlights.
Got them back and they look brand new! Really worth the effort.
Installed a new set of fog lights as well and installed some LED halo angel eye bulbs and LED headlight bulbs. Makes a huge difference!
Also, replaced the sill trims as they had seen better days.
My radio was also not working. No sound but the radio turned on. Managed to find an OEM radio in almost new condition and installed that and had sound again!
There is a list of items that i have replaced on this car. Unfortunately with work etc i didnt get a chance to take pics of everything.
I have spent a bit more then i wanted to on this car but i dont regret it at all. Its such a pleasure to drive.
Here's just a small list of items replaced on this car.
Still a few things to sort out but will happen in due course. Just need to do the gearbox service but toying with the idea of an 8HP swop into it! Lets see.
A few pics i snapped recently after a bit of a wash. Still needs to go in for a full detail soon.
- M Sport door sill plates
- EGR thermostat
- Coolant hoses
- Window switch
- High-pressure fuel pump (rebuilt)
- M Sport front fender liners
- Replacement OEM DDE 4.0 EDC15C4 ECU
- Radiator
- Tyres
- OEM replacement radio
- Turbocharger Reconditioned
- Rear main crankshaft seal
- FSU (Final Stage Unit) resistor
- Turbocharger gaskets
- Engine service, including:
- Engine oil
- Oil filter
- Air filter
- Cabin filters
- Diesel filter
- Gearbox mounts
- Exhaust rubber mounts
- Tappet cover thread repairs
- Exhaust manifold stud repair
- EGR thread repairs
- Headlight lenses
- Headlight adjusters
- Fog light bulbs
- Air-conditioning regas
- Auxiliary cooling fan / air-conditioning fan (67326921354)
- Door rubber seals
- Interior components:
- Driver's seat
- Steering wheel
- Headlining
- Exterior bodywork and cosmetic refurbishment:
- Rear right quarter panel
- Front bumper
- Rear bumper
- Rear left panel under tail light
- Side sill
- Paint correction and cut & polish
- Wheel refurbishment
- Additional parts and accessories:
- Bonnet shocks
- Boot shocks
- Angel eye LED bulbs
- Coin storage compartment
- Front and rear cup holders
- Airbag clip
- HVAC buttons
- Fog lights
