E39 Touring M5
Peter@AEW
A bit of progress on the touring.
Although we cut the floor from the sedan I was not entirely sure that the thickness of metal used in the sedan would be sufficient for the touring so I acquired 1.2mm steel to cut a new floor from.
A few pics of the new floor in place although not welded in yet.
Benji
That is a lot of work that goes into the floor, didn't realise the boot slam panel also needs to be removed. Good progress
Peter@AEW
excuse my ignorance Peter. Was the floor cut for exhaust/fuel tank reasons?
It was cut and modified to accommodate the right rear silencer as well as the battery.
Normal e39 cars have a spare wheel and battery location on right rear.
M5 uses a flat floor and the battery is located in a tub center of the boot.
Peter@AEW
So...
The rear floor is finished and is ready for paint.
For anyone contemplating such a conversion budget a princely amount for the boot floor conversion.
Prices have increased since I did Firi's 635 boot floor to astronomical levels.
Peter@AEW
And.....the touring is painted and I am a few randelas lighter but very pleased with the outcome.
Come January I shall start with the strip down of the interior to transfer the wiring harness from the M5 and have the roof lining done in Alcantara.
I have already had the M5 windscreen which has the Light Sensor on it fitted to the touring.
Overall I am satisfied with the outcome.
Peter@AEW
On a different note I should like to install a refined sound system to the car with a modern nav system touchscreen etc.
I am thinking of having a custom made sub woofer installation on the right rear where the battery previously resided but will need someone to fabricate a new cover to support the sub (maybe an 8" unit)
Any thoughts advise pointers etc would be most welcome as I know little about sound and what will fit in the car without it being butchered or over the top bling...
NBN
Speak to Abdullah of autosound Gezina... He can also do any leather/Alcantara work and Lazer Embossing for you at the same time
FISAACS
Hi Peter
I have an older version in my e39, looks OEM and meets all of your requirements. With the addition of the I-Bus App you have access to all of the high obc info.
7 inch Octa core Car Android Navigation System 8+256GB QLED IPS Display built-in DTS Digital Sound DSP ChipsetFit for BMW Car DVD Wholesalers https://share.google/cCgTk72cq00hGaqxK
Top Bottom
