F30 - 330d Highest Mileage
Hey Guys
Trust everyone is well.
Just wanted to check whats the high mileage f30 330ds doing out there and issues faced at what km, just so everyone can maybe start with preventative messures on their vehicles
Mine:
2016 F30 M SPORT 330D AUTO
Current km: 200 300km
Coolant flange replacement - 150 000km
EGR Delete - 170 000km
Front suspension refreshment including front shocks, all round, pads etc - 180 000km
To Do:
Gear box service as this was never done in the car's history.
momo1
im currently on 127000km
did about 10000km in the last 18 months and had all 4 shocks and shock mounts replaced, all 4 brake discs and pads replaced.
coolant flange , stabilizer links and a gearbox service.
note that except a noisy stabilizer link non of these components failed and only had them replaced as preventative maintenance.
things I'm considering doing this is year the vibration damper pulley, but not 100% sure if needed on the 330d as they were mainly a concern on the 320ds as they ran slightly rougher.
longhorn
I have done the following so far:
  • Water pump, it failed @ 210000km
  • This year I replaced all shocks incl. mounting and Tie Rod Ends
To do:
  • Stabilizer links (advice from previous service)
  • Steering rack bush kit (advice from previous service)
  • Rear brake discs and pads
I haven't done gearbox service.
Mine:
2015 BMW F30 330D M Sport
Mileage: 257000km
Anees
2015 F30 330d
Current Mileage - 229 100 km
150 000Oil ServiceMotul oil, Mann oil filter
154 924ReplacementCoolant flange leak repaired
160 000Major ServiceMotul oil, Mann oil filter, Liqui Moly Ceratec, Blueprint air & cabin filters
170 000Oil ServiceMotul oil, Mann oil filter
170 000Cosmetic UpgradeBlack and white BMW badges installed
180 000Oil ServiceMotul oil, Mann oil filter
190 000Oil ServiceMotul oil, Mann oil filter
200 000Major ServiceMotul oil, Mann oil filter, Liqui Moly Ceratec, Blueprint air & cabin filters
200 806Tyres ReplacementGoodyear Eagle F1 Asymmetric 3
210 100Battery ReplacementFirst Battery LN5AGM, 36-month warranty
211 000Oil ServiceMotul oil, Mann oil filter
216 098Front Brakes & Diff OilFebi Bilstein front discs, Hella Pagid front pads, brake wear sensor, diff oil Motul Motyl Gear 75w90, coolant flush 50/50 mix, brake fluid tested, coolant pressure tested
218 700ShocksISC Advanced Street Spec Coilovers. Height and Dampening Adjustable
218 778Oil Service, Engine & Gearbox MountsMotul oil, Mann oil filter, LM Engine Flush, OEM Engine and Gearbox Mounts
joelorgat
To do:
Mine:
Mileage: 257000km
Amazing šŸ‘
joelorgat
2015 F30 330d
Love the strict maintenance records, your car must be running like brand new.
How much was the coolant flange replacement and Labour?
And have u tuned and did dp yet?
Anees
Alhamdullilah, car is running well. Some suspension components will need replacement soon but nothing that is compromising the ride right now
Coolant flange was R370 and labour with coolant flush was R1800 but this was back in August 2023
Mods done:
Stage 1 tune
DP + Exhaust
XHP
joelorgat
Mods done:
Stage 1 tune
DP + Exhaust
XHP
Shukr bha, definitely doing flange and coolant at 100km jzk.
joelorgat
My 2015 needed a full steering rack replacement at 260 xxx kms. Doesn't seem to be a common issue so I might have just gotten a bit unlucky
Thats good mileage right there to be replaced, when I serviced recently i was suggested that i do steering rack. Is the damper pulley a common replaced thing on the 30ds?
Schalk94
The damper pulley is a common replaced item on all 20d's and 30d's since inception. From about 150 000km it might become due
joelorgat
Good to know, is there anything else?
My friends 320d oil filter housing cracked do he had to replace it with a coolant flush. Costed around 9k. Is that also a replaced item?
Im making a list of things needing replacement so I can budget accordingly.
Schalk94
I am not really aware of common issues on oil filter housings apart from the gasket that might start leaking,as we have had it on one of our 30ds.
Apart from that and what's mentioned in this thread,there aren't any other common issues.
