How dark is the windscreen tint?
Is it legal?
I tinted just the top edge of my car's windscreen.
Is it legal?
To add, what’s the visibility like at night ?
Looks good. How is she keeping up, mechanically? It's been 7 years, right?
I'm with you on that. You buy a 320d, you marry a 320d😅.An absolute dream mechanically bud.
Correct, got the car in 2017 and going to keep it until the wheels fall off
What I have done thus far:
Oil services every 7500kms
Other filters as due
Coolant and brake fluid flushes from time to time
Gearbox serviced - really cheap on the manual (around R1500)
Brake discs and pads (Oem parts)
2 x Wheel speed sensors (Febi from GW)
To do:
Vibration damper
Suspension refresh
BC Coilovers that I purchased years ago and haven't fitted yet
Clutch replacement when needed (purchased this years ago as well and have kept)
On the manual, what's rpm @ 120km/h? Haven't had the chance to drive a manual diesel 20d/30d yet. I'm sure first gear is non-existant?
This is interesting, I recall ZF bragging that the ZF8 was one of the first auto boxes which was lighter on fuel than a manual?Overall the manual is probably not as quick but definitely lighter on fuel than the ZF8 auto.
I could be wrong, although chances are it is under certain conditions and compared to a 5 speed manual or something along those lines.
Something I need to look at and I would like some advice from members on is the best way to get bass from the trunk into the cabin. Options would be:
1. Cutting the skihole
2. Cutting the backboard
Not sure which is easier or if there are any other options.
Bass is pretty good at the moment with the band pass enclosure but could be better with an opening to the cabin.
