So it has been some time since I last posted.
The car is about 90% there we are struggling with the knock sensors picking up the flywheel harmonics above 6000rpm so I think I will need to look at getting a single mass flywheel and clutch going.
Then yesterday after trying to log the car it started shaking heavily, Turned out my tires decided to let go on the fronts so I had to get them replaced before we could continue with the car.
The car has had a few revisions on the ecu now and we got it to a point where its as safe as possible with it being a track car mainly. Boost is being kept at around 1.4 bar and timing is quite low to try keep it running.
Max power was 305WKW but this was when it would pick up the super knock on cylinder 6 and we decided to turn it back just a bit. Currently it has just the slightest misfire in the higher gears but it feels much more linear and smoother throughout the range. Its also suspected the actuator currently being used isn't giving enough motion to allow for better control so that is also something to change and see if it helps in future.
Here is a short video of the how the car sounds.
