Out with the old and in with the (not so) new.
DangerD
Detail done!
Budleigh
Beemerbro said:
It would be interesting to hear ZF's procedure of changing ATF because as far as I'm aware you can't remove all the oil as about half of it is retained in the torque converter. To get all of it out you'd have to take the whole transmission out and open it which is very costly. The usual procedure that I know is commonly used is to drain whatever comes out and refill, drive for couple of thousand miles then drain and refill again and repeat this three times and by then most of the old oil will have been removed. I've done this myself twice in SA on my BMWs and have just completed a total flush here in the UK on an Astra that was done by a local workshop and they followed the same procedure.
Now I had a look at ZF quotes in a car Magazine last year and was shocked at the prices they were quoting for an autobox service between R25k-R35k. I wondered whether this was for each visit you attended and if they were using the method I described, does it mean you will pay that figure 3 times?:rage:
Ask Duncan auto how they do it, and I'm pretty sure they will tell you it must be changed two or three times for a complete flush.
I did it myself and the total cost for 3 ATF changes came to around R5000 for 15 litres of oil, Febi filter, BMW gasket, BMW sump screws. I bought all of it in London. BMW SA will ask for about R600 a litre of oil. But if you do some research of the specific oil required you might find it a lot cheaper elsewhere. Your local garage that you trust will charge you far less than ZF I'm sure.
If you do go to ZF ask them how they do theirs so we can hear more.
I think that R25k-R35k bill is if your gearbox has eaten itself. Normal service is under R6k.
Sent from my SM-G930F using Tapatalk
Beemerbro
Wow that's really reasonable and realistic price tbh.
But it will be useful to hear precisely what they do for that price cos gearbox service could mean anything .
Thanks for sharing that bit Budleigh:thumbs:
DangerD
Update on fuel economy:
I’ve been driving this car for two weeks now. My expectation was that my fuel economy would be better than the pre-LCI 320D that was on 250 000km.
Unfortunately, the economy has been slightly worse! It isn’t cause for alarm but a little disappointing. To top it off, I’ve been very conservative with my driving style (way more than ususal).
Anybody else have a similar experience?
The car is booked in for a filter service tomorrow, hopefully things improve after this.
My figures were as follows:
05’ 320D (Manual)
- Daily driving (mixed between urban / highway – somewhat spirited driving)
7.0 l/100km
- Long distance
4.0 – 4.2 L/100km (Jhb - Dbn) (best was 3.8!!)
4.8 L/100km (Dbn – Jhb)
11’ 320D LCI A/T
- Daily driving (mixed between urban / highway – conservative driving)
7.4 l/100km
- Long distance (will be updated after this weekend)
:dunnoanymore:
KPM3_30
Senior Moderator
Unfortunately it doesn't make sense to compare them, since one was a manual and the other is an automatic, not to mention that the newer car has a more powerful engine.
The auto-box can add up to a litre or more per 100km, depending on the route/driving style. Direct comparison between an E90 320i manual and automatic, the automatic used 2l/100km more, with a similar driving style. The fact that an automatic will shift up early or outside the powerband, then you kickdown to get it back into the powerband - this all uses extra fuel, which contributes to a higher consumption.
That said, the ZF6 is still one of the earlier automatics, that 'use' fuel to function. It's only the newer ZF8's that offer fuel efficiencies from the gearbox.
DangerD
Thanks bro. I was hoping that the answer wasn’t about the box.
Looking at the claimed manufacturer figures, this clearly doesn’t translate well into the real world (between the two models).
KPM3_30
Senior Moderator
Those claim figures are a big 'LOL', achieved in a controlled environment at xx degrees, with xx amount of throttle, at xx speed, on a xx incline, with xx wind speed... You get my drift.
Those claimed figures are just that, I tend to not pay attention to that and go on what the average is from real owners.. When it comes to pre-2012 BMW's, manual was always the clear winner for frugality, especially since you had all the control you needed in the palm of your hand.. You can manipulate driver inputs to decrease fuel consumption, whereas the automatic box does the 'thinking' for you.
My 335i manufacturer claimed fuel consumption was around 9l on a mixed cycle, it was closer to 12l with that autobox and moderate driving :fencelook:
DangerD
I suppose the test conditions for a manufacturer has to be as consistent as possible, for the purposes of validity and reliability of scores across all vehicle types.
And... assuming all testing conditions are the same, all the manufactuer specs I have read, point to the LCI being more frugal than the pre-LCI, for both box types. Even though we know that the real world figures are higher for both, based on the manufacturer claim of the LCI being lighter on fuel, I would expect a real world figure on the LCI to be less than the real world figure of the pre-LCI.
But I hear you, how it translates into the real world is questionable. At the end of the day, a 0.3l/100km increase is nothing to complain about when I don't have to stick my clutch in every 5 seconds.
Would be nice to hear what other 320D owners have experienced when upgrading to other models.
kramz
Difference in the consumption is the manual vs auto bru. Also I've heard the guy who suggested the detail to you is a legend :smilebounce:
DangerD
Yeah, the Business Development Director for the detail company
:roflol:
Sent the car in for a service this morning. Keen to get it back and test it on a long distance trip this weekend!
maleven-GP
I'm actually on 9.2 to 9.5 with mixed driving on a 335i manual (Jozi traffic).. The newer 8-speed auto box is tops though..
