plane crazy
Greetings
Seeing that I've not reached the required minimum of 50 posts can't post under the parts wanted thread...
Would appreciate it if some of the forum gurus could give me some pointers on where and how to find the following...
So for my recently acquired '85 635 looking to source the following:
Audio fader rotary controller- the vehicle has none in the centre console, previous owner installed aftermarket immobilizer with override socket in dash (I suspect the fader control was removed to facilitate this- on the positive side no new holes made in the dash...??)
I would assume that this is a pretty standard part for all 1980's Beemers?
Similar to:
Then a more tricky(expensive?) one:
Door seal rubbers, irritating wind noise drivers door- the door seal rubber was clearly repaired at some stage- so where to source replacements?
I'm new in the classic (?) car game so assistance needed!
Many thanks
PC
Similar to:
Many thanks
PC
