M3boi
Im just waiting on a ECS&FCP&Amazon order to come through...the shipping guy says it is 48kg worth of car parts. Christmas is indeed coming at christmas![]()
You hope! 😂
Indeed, ordered it all from Bertie, how did you know?Bertie is a legend!
Saw his name on the waybill sticker haha. We ordered almost all of our e34 m5 parts from him. Super helpful guy!Indeed, ordered it all from Bertie, how did you know?
ahSaw his name on the waybill sticker haha. We ordered almost all of our e34 m5 parts from him. Super helpful guy!
Going to get quotes in the new year,The level of detail in this is going to be insane. Who is going to spray it for you, Alfa?
I'm sure Bertie will be able to sort you out, should I pm you his email address?im excite....do they stock E36 M parts too?
thank you that would be niceI'm sure Bertie will be able to sort you out, should I pm you his email address?
Howzit NirvashAnother update:
Some goodies arrived today!
ZHP weighted shift knob (yoh can't wait to feel this on the M5, it's lovely)
E60 OEM shift lever - basically an OEM short shifter kit for the E39
Turner Motorsport Poly shifter arm bushing
OEM shifter ball bushing
5mm ECS Tuning wheel spacers X4
With extended wheel bolts
Having 2 sets of style 65's, I'm going to run a square setup setup of wides on all 4 corners of the car, more front end grip, less understeer, better look/aesthetics.
The 5mm spacers in the front are to make sure the wheel and 275 35 R18 tire clear the strut spring perch. At the rear its just to make everything square and look good!
Hope there is no rubbing, but from what I have read up it should all be good!
Hoping to get the car started again tomorrow with a new Starter Relay...🤞🤞🤞
View attachment 19581View attachment 19582View attachment 19583View attachment 19584View attachment 19585View attachment 19586
Try Imcomex, they had SWAG kits in stock at some time, not the best quality, but also not the worst.Howzit Nirvash
This looks awesome...i am also looking to get a short shifter "kit" for mine do you mind sharing more details please...also I called BMW to find a quote on timing kit: chains and guides and this is what I got:
Upper: chain and two tensioners: R8824
Lower: Tensioner chain and 3 guides R13 465
Where else can i look or should i just go with it?
I have a donor car but i do not want to use the used parts...
The short shifter kit is basically just an E60 Manual shifter which slots right into the E39 and has a shorter throw. Quite a common upgrade for the E39.Howzit Nirvash
