NavZ
hanopp said:is dumping the clutch bad for the 330i ? what could happen, bcause i dump it on 4500rpm most of the time and it launch like a rocket
4500 sounds high, I thought 3000 was close to optimum for a E90 330i Manual launch. Well you rev a bit higher so when it drops, it takes at about 3k.
If you still have your CDV then you aren't doing a true 'dump' anyway.
So you might even be able to get faster times without the CDV.
It limits the clutch fluid so you can't put too much strain on the car but apparently it makes your clutch wear out faster.
I don't dump the clutch so I plan on removing the CDV.
