Salt
Hi all,
Reason for my post is this:
1. I am keen to try improve the handling by decreasing the floaty feel under hard accelleration.
2. Not increase the already relatively hard/bouncy ride.
On point no 1 - my control arms (wishbone & tension struts) are approaching replacement time. I've read a few posts on the net about installing the F82 M4 control arms. The lower control arm apparently gives more camber which improves handling. It widens the track of the front. You can also add the upper control arm to essentially centrer the wheel again as it was with the stock arms but still leaving you with a wider track. Some posts mention you need to adjust the head lights after as well and that special washers are required (12.2mm and 6.3mm (12mm ID, 30mm OD) stainless spacers/washers - which need to be custom made, these are not off-the-shelf BMW parts.) - not sure on that. Has anyone done the M4 control arm upgrade - is it worth the effort and cost really? Is it a simple bolt on change - no custom bits required? Did it improve the handling that made it worth it? Or do I just replace with OEM/similar and hope the fresh kit makes a difference?
On point no 2 - I have considered the Koni Active Specials as they seem to offer something in the middle of a little better comfort but still good for spirited driving with the passive dampening - I've done some reseach online and the reviews are pretty good.
Appreciate any input or advice.
