jayaynikkal
Congratulations my bru š¤ Enjoy her in good health
+1 regarding the quality tyres on a car like yours, could save your life evenSage advice here! I never paid the āIndian male under 25ā tax because of advanced driving courses and an insurer that factored that into their model šš½
Donāt fall into the trap of turning your TC off on normal roads⦠minor changes in conditions or surface can send you into the bush. As good as it is it also wonāt save you from total stupidity even if it is on.
Also somewhat on this note always have proper tyres. They donāt have to be the most expensive but donāt fit rubbish. Generally if someone is chiming in with a low effort comment like āIāve never had a problem with <insert dogshit here> on <insert totally different car and use case> ignore it. You will spot these types of things in almost all discussions or posts when researching things. That will probably be the most useful advice: sort though advice carefully because in 2024 apparently you canāt call people out on these views anymore š
