I've started doing some work on getting the condition of the engine and drivetrain into a 'known' state. This is the beginning of a fair amount of work that is required for me to be happy with the mechanicals.
First up, I'm doing a full service on the car. While I'm at it, I also want to take the throttle actuators apart in order to check the conditions of the gears. I'm not having throttle issues at the moment, but want to replace the gears as they do wear out. I can't seem to get hold of gears overseas, so I'll ask my brother in the engineering industry to get me some made up.
I guess you don't need to go to this level when changing plugs, but it makes it a lot easier (and believe me, changing plugs on this car is far from simple).
Looks pretty clean from the top. But this is purely surface clean I'm afriad:
Remove top air filter cover. I don't smoke Dunhill, so that must've been there for a while
Air filter and plenum pipe removed
Air filter base removed. If you only want to change plugs, you can stop stripping here.
Intake plenum has a little oil in there. Bear in mind this is 100k km worth so not something to worry about
Plenum removed
And those 8 glorious looking throttle bodies staring back at you! The throttle actuators are buried deep beneath the wiring loom in the middle. This is going to suck...
I decided to park that for now and change the plugs. This was a mission as getting the coil packs removed isn't fun if you don't have a puller tool. Also getting your plug spanner into Cyl 4 and 8 is very fiddly - but I've managed to get them changed and plugs torqued to 28Nm eventually.
Getting the oil drained is also a little more involved, as there's two sumps in the car and both have plugs that needs to be removed. You should also remove all the oil from the oil filter base as there's around 250ml of oil there as well.
For the last 500km I've been running 1.5L of ATF in the engine in order to clean it. This stuff is awesome at cleaning the internals of the engine. Compare the pic from before the change:
To after the change:
I also want to touch on the notion that the spark plugs on these cars have knock sensors. This is not actually correct; these are simply Platinum NGK plugs
Not too much to them to be honest. It is, however, true that the car doesn't have knock sensors in the traditional sense. The way it works is that it makes use of a process called Ionic Knock detection. In principle, a spark is ignited and then directly after the spark, the coil pack puts 400VDC across the spark gap and the ECU measures the resulting inoic spectrum to determine the quality of the burn. You can determine much more about the quality of the burn than simple knocking by doing it this way. Very very interesting considering the amount of spark and measurement processes, per cylinder, when the car is running at 9000rpm. Quite cool actually.
