ClintChristopher
Hi all, I am having an issue with a Mulf2 High retrofit issue, vehicle is a 2008 E92 335i, vehicle was built with Sa640 option so vehicle was pre-wired for Mulf2, I had to file down the white connector for the mulf,all other connectors fitted without any modification, I added sa644 and $6fl ,I now see the bluetooth option on my iDrive system but cannot switch the bluetooth on and the aux/usb does not work,I ran inpa and pulled the vehicle information but don't see the Mulf present, when I run Ista P it gives me am error that there is no communication with ULF-High, I did notice that when I plug in the Mulf the red light goes off after about 10 seconds,this is the second Mulf I have tried, I also changed vehicle production date which did not help,hoping someone can guide me the right direction.
