E90 320d Fuel Breather Pipe
NikN47
Hi everyone.
I'm looking for a fuel breather pipe for my e90 320d.
It leaks fuel whenever I fill up a full tank of diesel. My mechanic advises that its most likely the fuel breather pipe based on the fact that it only leaks when a full tank (first click) of diesel of filled, and there is no diesel smell inside the car.
I've tried searching online for the part but to no avail. If anyone can guide me on where to purchase it I would appreciate it.
naeem9
Your mechanic must be certain because that (replacing fuel breather pipe) is labour intensive work. It could all be the fuel filler neck which is not such a big and costly job.
This is located on the rear passenger right side. If you will your tank full and see a leak in that area it might just be the fuel filler neck.
