E39 540i Manual project
Lungs033
In the interest of wasting money, I sourced some E38 illuminated door handles which really should have been included with the car from factory. Makes it a lot easier to find the door handles at night and brightens up the rear as there is no lighting at all back there, except for the window switches...
I got a bit lucky and found a set of 750iL extended leather & wood trim seat backs which clip straight onto my "standard" comfort seats. What is better than wood? More wood! And leather ofcourse. Fantastic waste of money, but hey, I can now say that 5 pairs of seats have given their life to make my one, admittedly awesome pair. Frankenstein concoction of E39 comfort & sport, E60 comfort and E38 "highline"
Excuse the dirty interior...
Anyway, moving onto real problems; I had a bit of a shudder from the propshaft between 80 -120 and there was a weird clinking sound when changing gear which turned out to be play in the rear "CV" joint on the propshaft. After much gnashing of teeth, I got my propshaft rebalanced and the CV replaced. Much better but perhaps not perfect.
This car has always had a bit of a difficult shift, generally taking on characteristics of a bus, with ensuing unwanted left hand exercise. I tried running MTF, then switched to ATF, then went for a 50/50 ATF/MTF mix which seemed to give the best results, but far from satisfactory. Under the advice of a gearbox specialist, I am now running Castrol BOT 402 and can say the gearshift is actually quite acceptable. Win! I am toying with the idea of installing a DSSR as I have about 15mm of left/right play in the gearlever caused by my original shift rod. Everything else is new.
Next up, I need to replace the camshaft position sensor and the auxiliary fan which both are nowhere near as important as wood trim!
Nice touches on the custom seats and the door handles really adds. The car is slowly becoming a 1 of 1
Benji
I should probably update this thread now that I have progressed on the path of emotional recovery...
We had planned a little George to Capetown roadtrip in the E46 touring as there are some accumulated car parts at a mates house that I wanted to bring back with me. I was focusing my time on the touring to get it ready for the long road, only to discover the week before it has a bearing knock due to a blocked oil pickup tube 🤦‍♂️
No worries, the 540i is supposed to be the roadtrip car anyway, so this is a bit of a serendipity. All hands on deck to finish the 540i after having received it back from the paint shop (again). I am still not happy with the paint, the roof and drivers side fender need to be repainted, but the paint shop is refusing any more work on the car. The ombudsman is now involved. Anyway...
The SO got involved helping me with "easy" jobs like cleaning up the interior, applying leather treatment and applying wax on the paint while I got on with "final polishing" the paint, replacing the windscreen cowling and replacing the auxiliary fan and air bleed pipe on the radiator which had a small leak and what I believed to be the cause of the disappearing coolant...
"new" bonnet liner
New cowling and windscreen trim:
New 02 sensors which fixed a bit of a hesitation the car developed after the paint shop - almost like it had turbo lag:IMG-20250515-WA0034.jpg
"new" mats and some M-sport door sill trims. Not technically correct, but I figured the old girl deserved more than one M badge:
I also got the windows tinted. Nice and clean, reassembled and ready for the long road
After a 5am start while making "swift progress" we had to perform an "emergency brake" due to an accident which caused a 30min delay. I let the car idle a bit with the heater on to allow the motor to cool down before switching it off. When I climbed out, I noticed a little coolant puddle under the car. Coolant was coming out the cap (which I had pressure tested and confirmed releases at 2bar). Oh dear. I started the car to let the system circulate and all seemed fine. About an hour later I get the dreaded check coolant warning but could not actually open the coolant reservoir as it was under crazy pressure and would immidiately "boil" which was strange as I had an eagle eye on the KTMP which never went over 97C as I am running a cooler 95C thermostat. We pushed on with one eye on the coolant temps and one eye on the road till about 2 hours from George while dispatching some slow moving traffic on a mountain pass - the suspension fully loaded around a bend doing 140, the rear of the car "lets go" in a spectacular and butt clenching fashion. With a lot of luck and a bit of skid pan skills (thanks BMW Club!) I caught the car and brought it to a safe stop. My first thought was that we had a blow out, but the tyres all looked OK. Weird. But even more weird, the left rear had about 30 degrees of rear steer...not something fitted to an E39. One of the suspension bolts had worked itself loose! Fucking hell! Luckily the bolt had not fallen out and after unsuccessfully trying to reinstall the bolt using the "widow maker" jack, we limped to the closest town 7km away and found a Oom who helped us reinstall the bolt and also check the other side which was also loose. At this point we properly opened up the cooling system to find it requiring a significant but not too alarming amount of coolant.
The unplanned pitstop at a garage in a little Karoo dorpie called Willowmore - very nice people who assisted us on a Saturday afternoon
We safely arrived in Wilderness without further incident except almost running out of fuel on Outeniqua pass...this thing drinks! We averaged about 10.5 L/100km on the drive down; considerably worse than I was expecting. Maybe it is the shorter diff ratio?
Many insects were sacrificed in the name of progress. Overall, besides the stress from the cooling system, this car is a dream on the open road. The seats are supremely comfortable with no aches or pains after 10 hours on the road.
We took the scenic route to CapeTown via Oudtshoorn, Ladismith and Riversdale. The difference in road quality in the Western Cape really took us by surprise. Tiny secondary roads in the middle of nowhere are in much better condition than National routes in the rest of the country.
We used about a cup of water to get from George to Capetown - not too bad, but did notice the cooling system was pressurized the next morning. Shit. Not ideal, but figured the car would make it back to JHB with a bit or nursing. Quick stop to check wheel alignment before the long drive home with the car suitably dirty:
We left Capetown at 5am, we wanted to do Bainskloof, but it was still dark, so decided to make progress and push on through the tunnel. The obligatory visit to the rev limiter in the tunnel with the windows down, resulted in a low coolant warning soon after. Shitty shit. Within a few km, I noticed the coolant temps rising so pulled over to find a very wet engine bay. Looked like the water pump gasket had failed. With a heavy heart, we decided to limp back to Capetown, averaging about 20km/L of water. Dejected, we left the car at a mate, ate some humble pie and rented a Polo TSI for a new journey start time of 10am. It was gong to be a long day. Luckily we could now make the Bainskloof detour, very well worth it and perhaps better to do in a small car as it is very tight and technical.
Beaufort West stop:
And made it home at 11pm, 18 hours and 1700km later, dejected, lacking confidence in my life choices and with a knackered back (the Polo seats are verified torture devices). To be fair, the Polo is actually a decent car (besides the seats) and really made me ask deep and meaningful questions about why I drive old BMWs. Are they really worth it, are they even fun at all, is the 540i specifically cursed, should I just sell them all, castrate myself and buy a Toyota. Also, I really shouldn't have had those edibles. Picture taken in Mexico, just before JHB:
Now to face the additional expense of getting the bastard 540 transported back to JHB. Making a mess on the tow truck in protest:
So there you have it, the other, less romantic side of old car ownership. The side you easily forget when you see a 540 manual advertised for 50k or a nice cheap L322 that would make an nice 8th car or that b30 swapped E46 touring that would make an ideal daily (when it works). And boy, do you need to have commitment, patience, alternative modes of transport and deep, deep pockets. Reminds me of that toxic relationship I once had, except here, I cant get out of it.
KPM3_30
Senior Moderator
Always enjoy your updates. Sorry to hear about the unfortunate events but I have no doubt, castration/Toyota ownership are not in your future.
I literally had the same thought this morning while bringing the E46 out of its 3+ month hibernation, question was answered on the way to work and old BMW ownership is the spice of life 🙃
Solo Man
Reminds me of a certain white BMW i owned in which i undertook a long road trip in shortly after i bought it. Must admit it never left me on the side of the road but would periodically bong and say "Drivetrain error" on the idrive with a momentarily loss of power and then back to full power. On the 4000km journey this perhaps happened about 8 times but would always revert back to normal power. On getting back home i by accident discovered the bottom boost pipe with a massive crack and a short tear along the underside (not visible from above) when replacing the boost pipe seals. I eventually got fed up with the car after spending literally hours searching for battery drain which would cause the idrive to message "Battery drain overnight". After spending a lot of money on spigot rings, gearbox and diff mountings, different tires, propshaft doughnuts and centre bearing trying to get rid of an irritating vibration between 100 and 120kph (my cruising speed on the open road) on my wife's advice i got rid of the car at a great monetary loss. And still it never left me stranded in about 20k kms of ownership thanks to my guardian angel. Was a very nice car to drive though! And it was also a beauty to look at! F10 520d M/sport! Even after all the effort and money i am still in a BMW and do not see myself driving anything else. If that happens might as well stop driving and let my kids take the car keys away from me!
NBN
As much as you say "old bmw ownership" I think the biggest issue ( for me especially) are the costs of new cars and also how devoid they are of driver engagement and driver feedback. So much emphasis has been placed on making cars so damn fast and electronic steering this and electric diff's that and advanced traction modes blah blah blah.... that it just makes a new car to me feel soulless.
Benji
Well atleast it's still a beauty to look at😍
Just as well, it is going to be a garage ornament for the foreseeable future
lol my E46 is in an involuntary 3 month hibernation as well!
Maybe - blemishes bring character apparently...but being left on the side of the road after having refreshed the whole cooling system is maybe taking it too far
  • Like
Reactions: NBN
M3boi
"new" bonnet liner
New 02 sensors which fixed a bit of a hesitation the car developed after the paint shop - almost like it had turbo lag:View attachment 28305
Beaufort West stop:
When I didn't hear from you about how Bainskloof went, I had a bad feeling something went wrong :cry:
Fordkoppie
I did that in 2021 and had trouble free motoring for about 1.5 years before I realized I had become a bitter person.
Life is so much better after that joy sapping soul-less appliance is gone.
It made me realize that you need something enjoyable as a DD to make the commute an event instead of just a mundane commute
Sibonelo
yes yes yes this gives me great confidence in fixing my project e39 M5 which has been sitting for almost a decade with no TLC let alone a mandatory oil change and a gentle start up! but hey what's life without a bit of drama and travelling with a tool kit and replacement water pump in the boot next to the coil packs.... trying to convince the madam " it will be all fine and dandy and oily hands are part of lifes journey and joys.. because life is too short to be certain you will make it to your destination with divorce lawyers being called! YOLO!!!
Mytfine
Too much time on the internet...
I used Sajco, but I will not use them again in the future. This is after I had a shudder in the E34 M5 after they "balanced" that prop, and now again with the 540i. They insisted that the shudder is from my diff and the play in the CV is normal. I then took the car to a few different experts and they all pointed to the prop. A diff doesnt shudder and clink, it whines and clunks. To be fair, they did then rebalance and replace the CV at no cost to myself, except the labor and swear jar contributions to remove and replace the prop. The balancing is still not 100% but I have learnt to lower my standards.
The irony in all this is I could have bought a brand new OEM propshaft complete with guibo and center support bearing for about the same money as Ive spent on my prop...so one learns
If you have issues again, try propshaft and cv joint empire in northring. Its a father and son outfit with loads of experience and is an all round super guy to deal with. He also does custom work no problems.
Benji
images
The creator of this meme is obviously a mechanic, judging by his grasp of the English language :ROFLMAO:
Holy crap, time flies when you do nothing! I recently turned a very nice girl into a woman and the wedding car was not a BMW. Shock and horror!
With all that going on, there has not been the energy, political will, time or funds to work on the problem child. I faffed about with broken window regulators (because BMW) and retrofitted folding mirrors. Because the one thing a blown headgasket needs is folding mirrors!
Lovely.
I confirmed my blown headgasket suspicions by carrying out a "pressurization test" of the cylinders and found cyl 5 to be pressurizing the cooling system. A light spot of shopping was in order.
Now to summon up the courage to actually do this job...Wish me luck please...on the headgasket job as well please
Sibonelo
Congratulation meneer! be honest the only reason its not VW wedding car is because had it been a BMW there wouldn't have been a wedding.. you would still be on the way! with multiple oil stains on the garments.
confidence is a big thing when it comes to fixing BMW and nothing gives more confidence like fixing small thing... that hero feeling... success with the head gasket. and remember once the oil leaves the shop it expires in a week so get cracking and fix that car! ( he says with his own project in pieces gathering dust!)
NBN
images
Lovely.
Best of luck Benji.... may she make a man out of you YET :p
Peter@AEW
Good luck as well as patience perseverance diligence and good humour for you shall need it all in abundance.
Do not angle torque the head bolts as per specification as you are likely going to pull threads.
Rather do them at 90Nm once and use assembly paste to coat the threads prior to installation (a little goes a long way)
Benji
Two months... That is how long it takes this particular individual to do a headgasket job on a BMW M62. To be fair, I probably spent around 10-15 hours on the job in between other commitments, moments of low inspiration and a weird amount of travelling for work.
This job was quite daunting for me, surely, a headgasket job is the mother of all mechanic jobs? About as deep in a motor as you're ever going to get. It actually turned out to be fairly straightforward; granted, I have done the timing chains on this motor before, so a lot of the work was repetitive.
Pop off the inlet manifold and valve covers
Shit small bricks while loosing the head bolts, furiously dispelling bad thoughts about warped heads, scored bores, leaking valves etc
OK...doesn't look too bad actually. Cyl 5 (the one on the right) being the culprit; showing clear evidence of where forbidden exhaust gasses mingled with the cooling system
Corresponding head:
The offending failed gasket
My professional (not at all professional) prognosis is that the car ran without the proper coolant mixture (so only water, probably from Lenasia) which caused corrosion to the gasket, leading to the failure. This corrosion and material buildup was not limited to this particular cylinder.
I performed a leak test on the valves (filled the head with water and let it stand a few hours) and all passed with flying colours.
Clean up the mating surfaces and check for any warping with a straight edge. All seems well.
Note how clean the water burning valves on cyl 5 are...
Replaced the check valves in the head, one of them was stuck open...
Inspect all bores to find they are all in very good condition. Did a light spot of "gasflowing" on the exhaust manifold welds
I replaced the alternator (old one had a noisy bearing) and tightened up the steering box while it was easily accessible. Gave the area the obligatory clean to remove all evidence that this engine once upon a time leaked oil.
Find the purgatory for leaves - mixed with oil in an alternator cooling duct till the end of time.
I was more anal that usual to ensure the threads in the block were spotlessly clean and I followed the torque specs to the letter. Torque all bolts to 30Nm in increments of 10Nm to ensure even torque. Then proceed to shit sizeable bricks while torquing the bolts 90deg, twice. Thankfully that all went smoothly, tho it was actually quite a workout with stiff arms the next day. That probably says more about my fitness than I want it to, but we can gloss over that.
New oil separator and seals, redo timing, button up the timing covers, cooling pipes, inlet manifold, valve covers and associated parts. Shit the largest bricks while cranking the car with fuel pump disabled to build oil pressure. No weird noises, so there is nothing left to do but start the car. Besides a noisy protest from the lifters that would rival any union protest, the motor started up and ran smoother than I remember it ever running. The picketing lifters soon hushed as their oil demands were met. This was around 11pm on the 20th November, just before boarding a plane to Namibia the next morning.
I did not sleep well in Namibia, but at least the beers there are cold and cheap
Upon my return, I thought it best to offer gifts and pampering to the E39 in the hopes of pacifying its deep and ferocious desire to inflict pain and suffering upon it's impoverished custodian.
To this end, I gave the bootlid one final polish and mounted the boot spoiler
I'm not so sure I like it, but gifts to the gods are not meant to be understood by the feeble human mind.
I may have got carried away and polished the whole car again...followed up by the finest Menzerna Power Sealant of course.
Did an oil and filter change topped (bottomed?) off with a new sump plug
Kinda weird to see the car with the bonnet closed. Completely changes the ambiance in the dojo.
Put an end to this procrastination I hear you say? Fine. See how the car squints in protest to the bright light.
And after a quick 100 km test drive, parked next to the much more reliable and much more neglected E34 540i. Eyes typically glued to the KTMP digital temperature reading. No issues to report. Fingers shall remain crossed while I put some more miles on the car if we should be lucky enough to have more than one day of sunshine in JHB!
I got the car started on 20 November, but test drove it on 16 Dec...almost a month of poor sleep. There are still a few outstanding items to do on the car; new water pump (new one ordered, currently running the original pump that came with the car) replace rear windscreen rubber, bumper beadings and numberplates, and it could probably do with new powersteering hoses, but these are less of a priority, I have other broken BMWs that need some attention for a change.
In all honesty, I am strongly considering selling this car if I can get a decent price for it. I am well over 300k into this bottomless pit :rolleyes: Maybe I need to drive it a bit more to restore trust, but it has broken my heart too many times, it might just be time to move on...
Lungs033
Nice work Benji. Your professional prognosis says the vehicle ran with probably just water, is this from the previous owner or probably oversight on your side while working on the car? .
At this point you've built a solid car which should be reliable going forward, enjoy it.
