BMW F90 M5 Maintenance, Issues & Out of Plan Items
TurboLlew
As with my F10 (and inspired by AdiS's original of the E46) I decided to pull together some general advice for the F90 platform now having owned my car since 2021. I have gotten more and more requests for info about the F90 and my experiences with it. This is by no means exhaustive and I will add things as time passes.
I took a decision to pay it up and keep it after plan expires in April this year.
I hope someone will find this useful and better than reading the rambling thread on my M5 that isn't really focused.
Firstly if you are only here to see what platform issues exist:
1. Coolant Expansion Bottle: The problem is only if the owner has not attended to it immediately leaving the bottle to continuously flow into the rearmost 2 coilpacks and plugs. This necessitates changing the entire bank of coils and plugs (per BMW's guidance). They started off just doing two but return visits seem to have been frequent. I have had this issue several times but it has been fixed now it seems. I would still at the very least do a drip tray. Best is to replace the plastic bottle with a billet aluminium tank (below). Aliexpress even has some nowadays. The car is VERY sensitive to loss of coolant before triggering the warning so I can't understand how owners have let it get to the extent I've seen in some pics online.
2. Clicking bits of suspension: The front is known to make strange noises at full lock if not fitted with two wafer thin friction plates in between either side of the hub. This would likely have been done on all cars by now. It is just noisy (fortunately) and not an actual mechanical failure. For a Japanese AWD car, this would have been noted (together with diff noises) as 'normal' but M5 owners are a fussy bunch :ROFLMAO:
3. Oil Change intervals: As with all BMWs the service intervals are absolute lunacy. Do your in between services as needed. Ditto for coolant and brake fluid. You may have spotted a reel or post of mine (not permanent) of my PRIOR F10 M5 being torn down after 180K kms (forged rods and bearings). This car had numerous oil changes pre-emptively done and looked quite good inside even modded at relatively high mileage. This was largely down to frequency of oil changes.
4. Toughening for mods: It is very easy to make bucketloads more power. For the love of God do a bearing and rod upgrade before you do crazy numbers.
5. Finicky lighting: the interior lighting on these cars is plastic welded to the door cards. It is difficult but not impossible to fix. The actual problem is the channel becoming 'cloudy' over time rather than a failure of the lighting itself. I have not experienced this myself but many others have. Exterior DRLs are known to fail with a telltale light-yellow look to them (Below). BMW is directed to replace the entire light unit which is fine under plan. If you are not on plan go to Firi and get some RGB or yellow DRL LED drivers and pop them in. You can lightly sand and polish the end of the channel if it has heated up and discoloured due to the failure.
whatsapp-image-2024-05-07-at-13-48-46-jpeg.22117
General buying advice
LCI vs. Pre-LCI
The front lights, kidneys and bumper are materially different between LCI and pre-LCI. Conversion kits exist but getting everything coded and working can be a challenge. This boils down to preference since I actually prefer the "angel eye" style to the proto-snake-eye look.
The LCI is only available in Competition form. With the G90, the competition naming was dropped entirely and won't be returning. On the pre-LCI the comp has the lower diffuser section of the bumper surrounding the tailpieces blacked out. This is colour coded on the base car.
The rear has a much more dramatic change than the F10 had. I am going to retrofit the LCI tails to mine. It is the only bit I really liked from the facelift.
On the interior, the LCI has a larger screen, newer iDrive version and the fully digital dash. The pre-LCI has an analogue-look dash with some metal surrounds to it. This is largely a matter of preference on the gauge cluster. For infotainment: both can have full screen android auto or carplay which is what really counts these days from an infotainment perspective.
I have noticed that most of the LCI cars do not have the Bowers and Wilkins system specified. Unfortunate, since this is one of the more enjoyable boxes to tick.
OIP.zRRjuTVJ5KsVvYtAKwzeHwHaHa
Competition vs. Base Car
Power bump from 441kw to 460kw with the same torque figure. This is not easily felt on the road.
Stiffer engine mounts which can be retrofitted
0.1s (claimed) better sprint to 100
Ride height is 7mm lower (you can go lower if you put the M Performance HAS kit on either car. Springs are 10% stiffer and there are shocks from the M8GC fitted to the comp.
Rear toe-links are different. this can be retrofitted to the base or can be upgraded on both with a Dinan kit.
In practice the differences had become so small from a hardware perspective that the comp became the defacto 'base' and because it was (probably) dumb to have a 'comp' sitting on its own, it was dropped from the G series.
M5 CS
the CS gets a further 7kw bump and the same 750Nm over a (claimed) wider band. It claims a 3 second 0-100 but this was happening even for base cars when tested by media or owners with Dragys. Laptime improvements are down to tyres and suspension rather than power.
Weight is down by 115kg via a carbon fibre bonnet, carbon ceramic brakes and reducing the amount of insulation. You can achieve the same (for a price of course) on any F90 and it won't be close to what a CS costs. You only get a CS for collector value.
The M5 CS comes with Pirelli P Zero Corsa tyres. They are not bad, but trust me - you are missing nothing. Stick to Pilot Sport 4S/S5 unless you just want the 'sporting credentials' of having these
Even stiffer engine mounts than the Comp - these can be retrofitted
The CS has alot of gold... you will either love or hate it.
Yellow DRLs
Gold versions of the Competition pack rims. They are the same rims.
Inside there is a 4-seater layout and carbon bucket seats with an embroidered logo on them.
The CS has carbon paddles and an Alcantara wheel (I have retrofitted both - plug and play and the paddles are just an M Performance part)
The CS also has a different rear spoiler (IMHO looks odd vs. the M Performance or base car) and rear diffuser (Looks good, but it is extremely expensive if buying OEM - 3-4x the price of M Performance).
Transmission:
The transmission is the highest performance tier of M-Steptronic box available (ZF 8HP). Pre-LCI has the 8HP75 and LCI has 8HP76 which has different software and some changes to the internals. It's got a modest torque handling improvement of 2.5% better. There are apparently some late pre-LCI builds with the 8HP76.
Note that the transmission service recommended by ZF is at 80000km and costs (at time of writing) around R8000. BMW initially called this a lifetime fluid but now lists the fluid change as required at a far higher mileage. Do this at 80000km as the manufacturer recommends.
The AWD system has been fine so far. I have used RWD mode a grand total of 3x in all the time I've owned the car and just to show people how it works 2 of those times.
In M mode it will not upshift unless you tell it to (it will bounce off the limiter just like a manual or M-DCT car). If you are requesting a lower gear that is mechanically impossible to get to, it will stop you as with any such transmission.
Seats and Interior
Seats are technically available in 2 styles (one being the CS carbon buckets). The normal seat design is available with heating (front and rear) or heated and cooling (heating on both, cooling on front). The latter are identified by perforated leather as opposed to smooth grain.
There are a variety of colours including two tone.
The seats are incredibly comfortable and adjustable. One of the best bits of the ownership experience has been getting into the car, hitting the button and having the seats get into position and wrap around you with lumbar and bolsters inflating and the upper backrest area tilting. Feels like donning an ironman suit LOL.
Alcantara headliner was an option
Although there is a leather-like material on all cars, full merino leather was a further option (top of the dash, lower dash and top of the door cards)
R.eae8b259a7b472ea78a487ec8f354b84
TurboLlew
Wheels:
Base 20": Style 706M
Cast (Manufactured by Ronal)
R.9ca8c111b34dd45db8d92755f9b4353d
Competition and CS: Style 789M
Forged (Manufactured by BBS)
8kg improvement in unsprung mass vs base
M Performance: Style 863M
Forged (Manufactured by Rimstock/Team Dynamics)
A further 1.2kg lighter than the comp/CS wheel (9.2kg vs base)
Exhausts
There are FOUR different exhaust options.
The base car has plain silver tips. This has vacuum actuated valves and is pretty quiet even with your exhaust button on.
The M Sport Exhaust is an option on the base car and standard on the Competiton. Many folks see this option and think they have the M Performance exhaust. You DO NOT. Easy to spot the difference from under the car even with a tip change. It is also impossible to mistake these two systems.
This has black tips, has a couple of baffles removed and is noticeably louder with more burbles available. It is still vacuum actuated. NOTE: If your car has petrol particulate filters (OPF/PPF) then it is going to be MUCH quieter than a pre-LCI car.
the CS Exhaust is a slightly different version of the M Sport/Comp Exhaust. The M Performance exhaust is still an upgrade to this exhaust and is fitted to many CSes that I've seen.
The M Performance titanium exhaust has NO VALVES - the sound changes are achieved via mapping. It has carbon tips and a perforated interior section. This is a significantly louder exhaust system. Unlike the prior generation that had Akrapovic stamps and embossing everywhere including on the hardware, this has none. The quality of the tips is also significantly different to the prior generation. Research suggests it is made by Eberspächer
img_5378_jpg-jpg.26557
General cost of ownership
I will repeat what I said in my F10 review: As with any such car this is relative. For a car that makes 440kw and can be daily driven for 100000+km without disintegrating, it is amazing. Compared to a Toyota Corolla? Not so much.
Oil & Fluids
Fortunately the car uses relatively inexpensive oil and I keep a litre in the boot just in case I need it. As mentioned above, of course BMW says it lasts a long time and of course you should change it in half that time. I have gradually changed my cars over to Motul and will likely do the same eventually with the F90. I would go 7500km-10000km stock and 5000km-7500km as intervals. This will be up for debate. I have stuck to the oil the car has always used (BMW branded Shell) but Motul, Ravenol and Liqui Moly seem to be considered upgrades.
As mentioned in the TL;DR section above, the coolant expansion bottle has been a headache, but one with a relatively easy permanent fix. I also had to change the cap at 60000km
coolant-jpeg.18502
Suspension:
Suspension is robust and I have had no issues. The car has had the M Performance HAS kit (rebadged/coloured KW it seems) for most of its life. This option has unfortunately doubled in price since I had it done. That said, I would still go this route if lowering.
Pic of HAS kit fitted:
Tyres:
I have had Pilot Sport 4S, A batch of emergency Pilot SuperSports and the Pirelli P Zero Corsa (CS star rated). Of all these tyres, the best suited to the car has been the Pilot Sport 4S. I can only assume the same will apply to the S5. The only other tyre I'd like to try still is the Potenza Race on it. I feel it may be a good match.
Tyres MUST be replaced on the same axle, but 4 tyres don't have to be changed if you have a major event. As with all M Cars, this has no run flats and no spare wheel. You can get a kit if required.
Battery:
The battery is a Lithium Iron Polymer (LiFePo) battery. It is much more expensive than a standard battery but will likely outlast an AGM by a long way. That said, it is important to keep it conditioned. BMW sells a specific CTEK charger for Lithium batteries. This is pretty inexpensive (under R2K) from BMW themselves.
General Engine
Having seen my F10s insides after 180000km, I would consider doing bearings preventatively at perhaps 120-130000km on this platform. This would be for my own peace of mind more than anything else. Carbon buildup is minimal on the F10 and I'd imagine improved further on the F90.
F90s have improvements to the fuel system (pumps, injectors), improvements to the manifold which reduces lag and makes it sound slightly more like a V8 (still not like a 63 or even a 550), different turbos and a redesigned oil control system.
Everything in the cooling system is slightly better stock, but it is still no replacement for swapping in eg: CSF Air to water intercoolers for our SA heat. The entire front of the car is a mass of heat exchangers. I did have to replace one coolant pipe at a cost of (if out of plan) R1500-ish.
Generally you should not have problems until you are making very large amounts of power or unless you are not following fluid change intervals. Nearly every car I've seen on behalf of someone or while shopping myself that has had an engine change has been due to either the owner neglecting the coolant tank issue and just perpetually topping up OR where the car was obviously modded.
NOTE: It is EXTREMELY cheap and easy to fit a mileage blocker to these cars - it plugs in between any CAN device on the network and results in these absurd mileage cars (20/30000km) which look like they have been through the war (yes even F90s look like this now).
Anyway that's it for now. Feel free to leave any questions or corrections below.
Katanator
Amazing write up thanks. A few have caught my eye with secondhand prices becoming very lucrative. Probably very little to no options to offer more car for what you pay.
Valve stem seal issues compared to F10?
TBP88
Great thread, I think as these become cheaper, sadly, they'll also be more abused - so the time to enter is probably now/the near future before the vast majority of examples are completely tits up. We're probably close to the bottom of market for them.
TurboLlew
Too early to tell for me on valve stem seals. The material has definitely been upgraded from what was in the F10. It wasn't a guaranteed issue on the F10, but common enough of a problem that they did change the material, not only for this but lots of the cooling system. In general, it is packaged so that there is improved heat management vs. before. However, the reason I'd say its early days still, is that this is definitely a platform that generates lots of heat in lots of places.
Engineers always believe they can defeat the laws of physics with cleverness, and while they sometimes succeed, only time in the field will reveal whether that is the case or not.
TurboLlew
The next 2 years will probably be the best time to be shopping as there are a number of cars coming off their extended plans and being traded in. Unfortunately, there are a number of cars (M8s, M3s and M4s as well) that are already in junk-status. These are NOT going to be cheap cars to maintain for someone who can only stretch to owning an 800-900K car.
The latest is to advertise the car with its cancelled plan and patchy history as a benefit for the same price as a car with motorplan from a dealer :ROFLMAO:. What is important to understand is that it is no longer just mods or repairs that trigger cancelling of plan: It's also this R750 goodie here:
There are a number of cars that I am convinced had mileage stoppers active for most of their lives. You can physically see evidence (tyre usage/replacement, brake condition, seat/interior wear etc). Rolling back mileage is one thing. What this device does is that it lives in the car, intercepts CAN signals and propagates and incorrect mileage across the entire CAN network. It stops or severely slows mileage and was undetectable for years as all modules in the car are impacted. However, recently cars have been caught because BMW now checks for mileage in a different location on newer cars.
While they may not have catastrophic failures there will be many big bills for brakes, tyres and suspension in years to come at which point they will be sold with the usual mismatched/junk/bald tyres, totally used up brakes and shot suspension. In the case of AWD cars this is also accompanied by failure of the transfer case due to having mismatched tyres or not being able to afford two tyres if they have a failure.
If you try shopping for any such car (AMG GT, Nissan GT-R, hell even a 370Z) you will find this approach to maintenance has been taken by people who somehow end up owning them. It is a tragedy looking through these because they were obviously very well loved when they were owned and for large portions of their life, only to be reduced to scrap metal.
There is also a market of complete crap mods for these cars. This ranges from literal AliExpress intakes/exhausts/cosmetics that 'tuning shops' rebrand to knockoffs of mods from actual tuning houses to things that have no business being near a car, let alone an M5. In terms of power, unfortunately everyone thinks they are a tuner with BM3 and MHD. This is fine for certain circumstances. I've had it on my F10 and its probably only gotten better by now. However, by the time you're going for anything remotely serious you need to get a custom tune and professional setup from a 357/Xcede type operation that can actually tune and check for issues and has an actual workshop etc... either using BM3 or their own platform/ECUtek etc.
Unfortunately, a whole host of cars are going to be destroyed in the above mess but that (as with every other generation of BMW) is just the way things go as they get to the bottom of their depreciation cycles. They will make for good parts sources in future at least.
Mytfine
I only have one question for you after driving an F90 M5 comp from dbn to Jhb for my bil who is taking a vacation from the mess in dubai.
How in the hell do you not get arrested in this thing. The speeeeeed , it boggles the mind.
TurboLlew
It can definitely feel like warp speed :LOL: but you do become desensitised to it over time to a degree
Great write up. I just recently purchased a Pre-LCI F90 which already has the LCI rear light retrofit and I agree it is so much better.
Where did you source your coolant tank from as I would like to do the same for peace of mind and longevity.
TurboLlew
I have a nearly new bottle still from BMW replaced less than 2000km ago so it's been on the backburner for now. Pics are a reference. By the end of this year I'll do the RK Autowerks tank though.
You import yourself and then Xcede can fit it.
There is an Aliexpress part available (below) but I am not willing to chance that, especially considering this is still a 2 piece part, let alone part of a cooling system and located near critical items. It is also not internally baffled as the RK claims to be. There are plenty of other things I'd chance from Aliexpress but not this IMHO - but risk appetites vary so I've included it LOL. They can make it for you in a variety of colours.
There is a drip tray that some guys have opted for if you have the revised bottle, but don't trust it. The problem I have with it is that it is so close in price to the billet tank for basically a piece of plastic that doesn't solve the root cause, you may as well just go the billet route IMHO. It's a similar amount of effort to fit both so by the time you've factored that in, it makes even less sense
I am not sure I trust the relocation kits either as they introduce additional points of failure and some drilling. However they are also in the same ballpark as the RK kit above from a price perspective.
I didn't know about the drip tray but that is just mitigating the underlying root cause of a fault bottle.
And I share your sentiments, I would not have peace of mind that an AliExpress/Alibaba part of such critical importance would perform as well as a part backed by many hours of R&D.
Luckily mine has had the bottle replaced as well but we know that it will eventually revert back to its former ways so I'll most likely bite the bullet for the RK Billet tank as well.
