Hi Guys,Coming on fine have done the disc brake conversion and got the body work in order time to start fitting and linning the body and door gaps,the strange looking units in the one photo are fans, we decided to install two fans per head in the engine bay because we dont know if we got enough air flow over the heads its a lot easier to do it now instead of trying to sort it out once the car is completed if we dont need all the fans it is easy to remove them
Okay guys, body work finished and prepped everthing removed out of car and now at the spray booth to get it final coat of paint will be silver same as Hans Stuck racing car
Hi guys, wishing all of you a good 2014 ,okay i have got the little beemer to fire up and drive. it sounds good and drives good still a little to do but should be ready for zwartkops the 31 january2014 cant wait.I should be running in little giants catogary just dont know what class (depending what times i run)that is if nothing goes wrong still have to set suspension.
