3 Cylinders misfiring,where do I start?
Anarchy05
Hi guys,
So ive had a rough idle a few times in the morning,and now and then,then one day it stuttered badly,I shut it of and started again and the problem was gone,though lately it feels sluggish!
This morning I scanned and found the following pending faults
P0303
P0403
P0603
P00aa
B2aaa
B2aaa
The last one not typed by error twice as this is how my obd tool showed it to me.
Where do I start as I want to fix it please I miss her being in a good condition.
And BTW my motorplan expired 14 Aug!
cRed001
If I'm not mistaken, those codes relate to a misfire in the cyclinder.
Check the spark plugs and thereafter the ignition coil.
This happened to me previously with my Opel and I experienced the same problems with the car idling roughly and being sluggish.
I changed the spark plugs and had the error codes deleted, it worked for me.
Anarchy05
I'm using an elm327 mini
And the Torque app,
Also this morning it was very bad but after standing in the sun a bit the problem is completely gone and drives normal again. I'm clueless
After it was normal again I scanned again for the codes but they stay in the section for unconfirmed errors,even after I clear the codes
Chavoos
I had a cold start misfire that vanishes after the car warms up a bit. Error codes were misfiring on various cylinders. If it's similar to this it could be leaky injectors .
I suggest you try new plugs, test coils(hopefully someone has spares lying around)
The way to check leaky injectors is to let the car stand overnight and remove plugs prior to starting the car and see of any of the plugs are wet.
Peter@AEW
Your codes are induced by a PCV related issue and not an electronics issue.
Check that you do not have a cracked pipe or blocked/leaking valve
Anarchy05
I will be getting a new set of plugs today and fit them,
a1exander- could you please elaborate a bit more?
PCV valve meaning?
And the pipes you mention is that boost pipes or vacuum etc?
Im rather thinking I have a leaky injectors,on a few cylinders, I had to dtart just now and it is the same again. Except it actually smokes petrol when doing this aswell
Anarchy05
guys,
is it worth buying an old model injector?
Part nr : 13537565138-07
13537565138-02
Not sure if these are even the correct ones havent gone to take a look yet and not too lucky with google.
Please help,I can get them for 3k,5 with part nr 13537565138-07 and one of the others
Oh and Misfire in the morning is waaaaaay better after some injector cleaner
Anarchy05
Im thinking I had dirty fuel or sumfin?lol. Ive got no idea.would you rather gues hpfp or coils?
Its only on cold start,after warm up its gone?
bmsportzn135i
Before starting with the injectors, first test your coil packs.
If you do need injectors, speak to Kish here on the forum, i know he had some.
Anarchy05
Turns out to be tappet cover Gasket leaking oil into the plugs
Can anybody in JHB or pretoria help me source a gasket as my small town cant supply
Chavoos
Check the actual tappet cover for cracks also.
Mine had the same issue. Had to purchase the tappet cover which came with the gasket.
Moer expensive
Anarchy05
Will I be able to see cracks before removing the cover? As I sent my brother to Bemows Pretoria today to get me a gasket
Anarchy05
Replaced the gasket today,quite a biggie compared to an old 8v motor...lol
Anyway,no cracked cover,just one issue,I broke one of the cover bolts off inn the hole,wil have to remove it next weekend.
I followed this tutorial,except I broke one bolt when trying to torque so eventually I ended up not torqueing the bolts
Anarchy05
Still having a miss on cold start today,still as rough and smoking a bit of fuel,until its warm then its fine
Pho3niX90
Check a1exanders/Peters response again.
If your problem is still there it could be pcv valve, I had multiple missfires on the x5. Eventually turned out to be the pcv valve. Google the symptomps and diagnosis of the pcv valve / oil separator valve
