3 Cylinders misfiring,where do I start?
M3_devil
I have a pcv valve if you in jhb area incase you need to test. I fitted RB pcv valve so have oem spare.Can assist aswell if need be.
know all to well feeling of a sick car.
Anarchy05
Wow, in the meantime I missed the whole pcv thing,thanks guys, I will only be able to check over the weekend. Unfortunately I am not close to jhb im in Witbank. Thanks alot
Pho3niX90
Originally from there. Got to hate those potholes.
Doing a quick google search brings up replacement pcv upgraded parts, which suggests it might be a common issue on the 135's, just speculating though.
Anarchy05
They sey you can test with a plastic bag over the oil giller cap or dipstick? Is this how I can possibly test?otherwise I'm just going to buy a new one and swop it out I dont know much about these pcv's...
Oh and BTW, you should come check the potholes,its spot some tar and win a prize...lol,the rain is horrifying the situation
Say not sey/
Anarchy05
I did the vacuum test with the oil cap,but there was no vaccuum or pressure.nothing happened to the bag. This was 2min or so after starting when the idling dropped down to normal with misfire present.
Should i rev the car while testing or get the engine completely warm first?
Also where can I get parts like the RB Pcv,and an oil catch can? i would rather upgrade the parts then fit OEM if it gives problems anyway
Pho3niX90
That does sound like a problem, but I am not qualified to be 100% certain what the problem is. Just do not rev the car with the cap off. Peter/A1exander will know though, I have trusted them with all my cars and haven't been let down.
Anarchy05
For now issue is sorted.no miss on any cyl after replacing plugs and valve cover gasket.where can I get the RB Pcv?
kingh135
Try replacing the coil pack. Bosch-Diesel Electric close to me in PTA West has plenty in stock for around R400-00- part nr 0 221 504 470.
Anarchy05
Yes,left the car standing,took the plugs out 1 by 1 checking for fuel,and nr6 was full of fuel looking as if it was lying in a bucket of petrol
Got new injectors but cant get the inpa to code it,darnit,but will manage soon hopefully
Hugo_za
What kind of trouble are you having with INPA?
Anarchy05
It keeps saying stopped as soon as I go to the injectors
But I have 64bit and I think that might be the issue.not too sure as it will be my first time using,my friends KTS doesnt want to do it,no options for my car
Hugo_za
If you are in the general Fourways area we can hook it up to Rheingold and see if that works. More than willing to help out.
Anarchy05
I'm in witbank,is it safe to put the 6new injectors in and then drive to fourways?
phat187
Hey guys,
Im having the same problem...
Misfires on Cylinder 1-3-6. I have replaced spark plugs, then replaced fuel pump and just replaced coil packs. Car runs perfect for a day or 2 then it starts again, i have read the error and now its only misfiring on Cylinders 5-6.
Last resort is the injectors but my car is due for its service so ill get the carbon doctor done aswell before i try that expensive route.
Cheers!
Anarchy05
If its multiple missfires on different cylinders try removing the covers to check for oil inside where your plugs go...might be the valve cover gasket sweating or leaking,that was my first issue,after that was sorted i had single misfires on cyl6, i the let the car stand for a while and removed the plugs one by one to check if they are full of petrol,sure as hell cyl6 plug was flooded,diagnosed injector 6
