2008 Z4M Roadster
Katanator
Congrats on the new wheels. I remember meeting Pete years ago, and this was tempting back then. You bought a good car and have also levelled up in so many small but noticeable areas.
Keep up the good work.
Thanks, the car offers a nice base to work from and is a pleasure to drive.
Katanator
Im undecided on the front belly plate.
1. Get new OEM
2. Manufacture oem like one from 2mm stainless
3. Plastic weld and patch up
Also got this little nice thing from Fruugo for R500-600 to make oil pressure testing much easier than having to access the port behind the oil filter housing.
Katanator
Contraption is a bit leaky but pressures looks awesome. 1 bar hot idle and up to 4 bar at 2500 rpm.
Katanator
Figured to give some plastic welding a go. Didn't feel like spending R6k on something that is just going to scratch again. Reinforced the inside with stainless mesh.
Benji
You must be high off those plastic fumes, but that looks almost as good as new and is functionally perfect (y) Sure beats spending 6k
Katanator
Getting to know the car and listening for noises I noticed something that I would like to attend to when removing the valve cover.
If any of the s54 owners or specialists could advise maybe @Clint@MMS AUTO @Benji @Peter@AEW
The engin makes a brief crackle/rattling sound for 1 or 2 milliseconds when revs are climbing or dropping fast, sound is around 1800 RPM briefly then gone. Happens when stationary as well.
Dont know if the vanos maybe actuates around this rpm range.
Fordkoppie
That sound is definitely emitting from the vanos.
Could either be the splien shafts, or a combination of that with the aux oil pump.
If you could just verify that the pump drive tabs havent broken off the hub, then its not a problem that needs attending immediately.
Katanator
Dont think they are broken since its not constant and only when vanos actuates. Had a chat with Peter as well and seems we all are in agreement its the spline shafts.
I did not order the rattle kit along with my new hub, seals and bolts :unsure::unsure:
Bruce88
Being on holiday is not good for opening or keeping a space open in the garage.
With a 6pot BMW petrol in manual on the bucket list going through options a lot of the roads kept coming back to a Z4M. S54 and s85 seems like a decent combo and some of the best BMW had to offer.
Hard to find a well taken care of sample at a decent price this one on the forum had my interest.
Link
Currently just below 200k km on the clock.
Previous owner attended to most critical maintenance items, bearings, clearances, diff, clutch, shocks, gearbox oil so my work will mostly be cosmetic. Mostly done by forum members Clint and PeterAEW. All records kept
First off a front bumper spray, dent removal and rim refurbishment. I would like to refit the OEM rims once these tyres have tun their course.
Some plastic items to be ordered, the typical parts ive seen worn on every Z4M.
1. Windscreen wiper cowl
2. Windscreen rubber trim
3. Safety belt guide
4. Floormats
On the mechanical side I plan below
1. Fuel filter change
2. Upgrade exhaust cam hub with 5150 motorsport hub
3. Upgrade vanos hub bolts
4. Replace vanos seals
5. Valve cover gasket seems to be sweating/leaking too much for my liking.
6. Rear main seal leak
7. Leaky power steering
Any other suggestions to bullet proof this thing mechanically. Should I consider water pump and injectors?
Hi have a set of injectors for you - rebuilt (New) from australia
Katanator
Thanks Bruce will PM you.
Small update, car still in for rear main seal and power steering leak.
Once back I will tackle the cam hub and vanos.
Apart from that a few new underbody panels and she is done.
sajk
Don't know if you got to the bottom of this. I had a similiar noise not on my z4m but on another m54 double vanos. After an anti rattle kit made no difference we put a brand new vanos unit on it. The noise was still there. It was the chain tensioner. The noise only happened passing through 1500 to 1800 rpm and was louder on trailing throttle. I still have z brand new m54 vanos unit (well it's done about 1k) sitting in my garage.
