Gavsadler's 130i M-Sport (E87)
Sorry to hear about the health issues and loss in your family. Sending strength to you and your family.
This shows the value of having dependable transport (and an extra car) for when these situations arise and the 130i is exactly that
gavsadler
Additional update May-2026:
Looking back, it has been an exceptionally busy year, with lots of projects on the go, including the various cars. Traditionally, the 130i has it's annual bits of maintenance and detailing and that's that. However, since the Concours last year, some plans and ideas were brewing in my head for this year. So, consider this the first official update of the "Road to Concours 2026" for this car.
During my brainstorming sessions, I went down the rabbit hole of itemising everything that could potentially be attended to, fixed, repaired or replaced. This was done as a blank slate job card, without any thoughts of cost. Thereafter, I added some costs to the line items, and got to a ridiculous figure: well actually it was a 6-figure value. This was simply out of the question. Obviously not everything needed replacing (I was never going for a full restoration, or to make the car undriveable because it would be too nice). So I decided on a handful of things I would do, which would improve the car overall.
The first of these tasks was the roof lining. About 2-3 years ago, it started so sag in the boot area. Surprisingly it didn't get worse in the back, however over the past 6 months, it did deteriorate up front around the sun visors. One of my friends in the detailing space referred me to someone and after seeing some of his previous jobs, I was convinced that it would be the right choice. I got in touch with Yatish from YD Customz, made arragements to drop off the car and he would get stuck in.
The car was with Yatish for 1 week. Essentially the 1st day was stripping, day 2 and 3 were to glue the new roof lining to the board and let it dry, as well as re-dying the A-pillar covers and sunroof surround. Day 4 was to reinstall in the car, and I then collected a day or so after that. I am very pleased with the work, and will happily recommend him to do work on other cars. (He also subsequently recovered a steering wheel for me, and will also be doing work on my other cars in future).
Onto some pics:
The upcoming updates will be a bit pic heavy with detailing prep....
gavsadler
Update July-2026:
June was a quiet month for this car, as I was busy wrapping up other projects and commitments. In July, I started off with some mechanical maintenance to get that done before the intensive cleaning and prep started.
Annual service time: new oil, oil filter, LM Ceratec and LM Hydraulic Lifter Additive were used. (I have an intermittent sticky lifter, so I thought I would give this a go and see if it helps). I also cleaned the Air Filter and Pollen Filter. Last but not least, the brake fluid was changed as well.
You may have read it elsewhere, but I purchased Firi's / Yulon's Quick Jack, and this has proven to be a game changer at home. I'm so glad I could make it happen.
gavsadler
With the mechanical stuff mostly done, it was time to focus on a few other things:
Airbag recall completed, new airbag installed (FYI, a new steering wheel airbag is approx. R17k)
Earlier this year, some family members were here from Oz, and they used the car to travel to Mpumalanga for a family emergency. On the way back, they picked up a nasty stone chip just above the driver's field of vision, which began to crack. There were a couple of other stone chips here and there, and these, together with the obligatory sand-blasting over a few years meant that a windscreen replacement was on the cards.
A Fuyao windsreen was installed, which I believe is OEM fitment/replacement on BMW? Anyway it looked pretty much identical to the glass which came out the car. There were no issues with installation.
I personally stripped out all the covers and shrouding below the wipers and windscreen, and requested that they only install the glass and leave everything else alone as I would be cleaning.
So behold, 19yrs of dust and dirt and grime. I don't think these covers have ever been off to clean the parts underneath. All that was about to change over the next 2 weeks...
And lastly, with my newly acquired lift in full operation, I decided to invest in some Powerflex jack pad adaptors. Soooo much better than the smaller, cheaper rubber ones I was using previously:
That wrapped up the activities in July. August would become the INTENSIVE cleaning month.
gavsadler
Update Aug-26:
The next few updates may be a bit pic-heavy, but it's in the interests of sharing, as well as for my own memory going forward.
With the windscreen replaced and all the covers off, it was time to clean. My thought process was that of cleaning everywhere possible, with the intention of doing a final clean a week or so before Concours (early September). I have no doubt that I will have forgotten some details, but I will do my best to document everything.
The first logical place to start was the engine bay. I dusted off my little steam cleaner which I have not used in some time, and that was predominantly used to clean any sensitive or electrical areas, as well as some areas where stubborn dirt and grime was not easily removed following other processes (at least initially). In other areas, cleaning took place by hand with a combination of cleaners and brushes. I also used snow foam on some parts too.
Any plastic covers, the airbox and other bits which were removed were cleaned and coated. The intention is also to (possibly) coat and dress the rest of the engine bay next month.
I removed the bonnet insulation and the bonnet and all the nooks and crannies were also cleaned
And everything reassembled again:
Heres some pics and a video of the Quick Jack in action. I'm so glad I made this happen, it has been used almost on a weekly basis since I bought it. First on the low setting, and then it's highest setting:
Another little change I wanted to make was behind the grilles. After fitting the black BMW Performance grills years ago, I was never a fan of the white of the bumper shining through. As such, at the time I made a temporary plan, which lasted a good long time. However with the focus on the details, it was a prime opportunity to do it better.
So the grilles were removed, the area was cleaned up, and I spent a Sunday afternoon doing some painting.
Grilles removed:
Driver's side painted:
Driver's side grille reinstalled, and passenger side painted:IMG_7406.JPEG
gavsadler
Update Aug-26 (cont.):
With the engine bay sorted, it was time to turn our attention to the wheel arches and undercarriage. We spent many, many days under here, doing things iteratively as we learned new techniques and found some products worked better in certain applications than others. Some key points here:
  • I learnt that there are nooks and crannies on a car that I never knew existed (same lesson applies to the engine bay)
  • The more you clean, the more places you find to be cleaned.
  • Cleaning from one angle is great, but then you slide under the car from a different angle, and once again... find places that still need cleaning
In the wheel arches, everything was cleaned nicely, but we knew we would circle back to the brakes at a later stage.
Everything that was metal (or at least the majority of the items), was cleaned, prepped and polished. Here the control arms and sub-frame are shining like new again:IMG_7425.JPEG
Some pics of the undercarriage. During our first cleaning iterations, we left the main covers on, focussing on cleaning and polishing the areas most exposed to the elements. One item which peaked my interest was the middle section of the exhaust. It looks like 2 different batches of steel were used during manufacture, because each pipe had a different end-result after polishing.
The back box would be polished at a later stage...
When we did get round to the brakes, everything was thoroughly cleaned with Iron Decon, APC and some other cleaning products. I also made use of P&S Metal Brite to bring some shine back. All the rust was removed from the discs too. You will notice some brush marks in the slots of the discs, but this would disappear later on after some driving.
This was the end-result on the rear setup:
And a few more exhaust pics:
For all of the above, the only real way to improve on this would be to disassemble everything completely, but at this stage I had no intentions of a tear-down restoration.
Also, while the wheels were off, everything here was thoroughly cleaned, and the wheels were polished and coated. I had a handful of chips on 2 rims, these were also touched up. The tyres would be dressed after the final wash and prep before Concours.
gavsadler
In between the back-breaking work of cleaning the undercarriage, I did a few other odds and ends:
New OEM jack points installed. The installed ones had taken some abuse from an old el-cheapo trolley jack. Never again...
The side indicators were looking a bit faded, so new OEM units were installed:
Yet another Sunday afternoon was spent removing the lower bumper grille, cleaning the radiators, treating the grille with Solution Finish and then reinstalling:
Aaaand back to the undercarriage. During our initial cleaning efforts, we noted that one of the "aero flaps" or whatever you may call it, was broken. So I managed to order a new one. This is what R420 of plastic looks like, lol
With about 2 weeks to go, I decided to remove the main undercarriage covers and clean everywhere. The covers themselves were cleaned and coated, and everything they were protecting was also cleaned. Thankfully this wasn't too bad, just very fine dust to deal with.
Also, something I wanted to get to spruce up the interior was a new set of floor mats. In reality, it was only the driver's mat which showed some wear, but alas, now I have a new set:
And with just 1 week to go until D-Day, the weather forecast was not looking great. After much deliberation and consultation, the Committee decided to postpone the Concours to the middle of October. This pretty much brought all activity on the car to a standstill.
gavsadler
Last update for Aug-26:
See, somewhere in the updates, I skimmed over the obvious. The interior was cleaned, and the exterior was polished, treated and coated as necessary. Some stone chips were also touched up. With the Concours being postponed, this deferred some of the last minute updates to closer to the time again...
Update Sep-26:
As mentioned previously, there was not much activity on the car in the month of September. It was pretty much ready to rock and roll, with the only plans being to give it a final engine clean, undercarriage clean, wash and interior clean.
Something else I wanted to do to the interior was to get a new steering wheel. For personal reasons, I wanted to keep my original steering wheel as-is (future memorobilia display piece?). As such, a few months earlier I had started searching for a replacement. There was no stock of an OEM replacement steering wheel at BMW SA. There was also no stock in the USA, in Germany, or even at any of the large Distributors (Turner, Schmeidmann etc.)
The next plan was to search for a used wheel and get it recovered. The plan was to use YD Customs again (who did my roof lining). This also proved to be an almost impossible task, with nothing available at the reputable scrapyards. I'll circle back to this option later on in this post.
So, with no new steering wheels available, and no used ones available, my next option was to search for a used wheel overseas. I eventually came across a company based in the UK, which had refurbished steering wheels for sale. This was around 7 weeks before Concours. The site listed everything as in stock, with 4-6 days expedited worldwide delivery. Winner! Worst case scenario, I would get the steering wheel after 2 weeks, with plenty of time to spare.
Here is where the drama started. After 2 weeks I enquired, as no shipping details were provided - no feedback. After week 3, I enquired again, and I was sent a tracking number. After week 4, no movement on the tracking number, so I enquired again. The seller replied that it is European holidays, and his supplier for the steering wheel (which he then apparently refurbishes) was not available. This annoyed me immensely, as not only was the "In Stock" claim false, but so was the shipping. All of a sudden I could not overlook the possibility that I had been scammed. With less than 2 weeks to go, I tried my luck searching for a local wheel again....
Eventually, less than a week before Concours, I got a lead on a wheel. I rushed to purchase this at the company's closing time, and thereafter delivered it to Yatish on a Sunday for him to start working on it. By Tuesday (week of Concours), it was ready for collection:
Some pics of before, during and after the refurb (I cringe seeing the before pics, lol):
During the refurb process (stupid sewn on cover removed to show the original leather):
Original leather removed:
And finally after new foam and nappa leather. I had it recovered in the same design as OEM, with the exception of adding M-Stitching instead of black stitching:
This wheel is also for sale now (see thread elsewhere), here are the pics I took:
The day after I had collected this steering wheel, the concours was postponed, so with some breathing room, I also postponed work on the car. It also allowed me some time to sort out my UK steering wheel nightmare.
The whole of September went by without any update from the Seller. I was convinced I had been scammed. I even opened a transaction dispute case with the bank, to hopefully try and get my money back (GBP430 odd). This would take them 3 months to investigate and process). I'm sure you can understand that me feeling glum was a bit of an understatement.
Then, without warning, my freight forwarder in the UK informed me that he received a parcel addressed to me. I knew I had not ordered any new stock, so maybe, just maybe, this was my missing steering wheel.
Four days later, I was pleasantly surprised:
A huge sigh of relief, and R13k (after shipping, duties and vat) has never looked or felt better.
So now I have 3 steering wheels, my original one, the refurbished local item, and this refurbished one from the UK (which actually turned out to have come from Lithuania). So, to round off my original plan:
  1. keep my existing steering wheel,
  2. install this steering wheel from overseas (due to being pot-committed)
  3. put the local steering wheel which was refurbished up for sale
That wraps up the September updates. Next up would be the final prep for Concours in October...
gavsadler
Update Oct-26:
We had about 2 weeks to prep before Concours D-Day. In reality, we only really cleaned the car the week before. All the usual cleaning was done, but no real intensive detailing work was required (this was all done in August).
Just a couple of updates to the interior...
My original steering wheel next to the one which came from overseas, the steering wheel boss, and final installation:
I also pulled the trigger on a new gear knob and boot.
Existing one:
New knob:
The floor mats I purchased previously were also fitted, and just like that. It was time for Concours.
To wrap up the "Road to Concours", it has been a journey for sure. Conservatively, between myself and my home assistant, we spent well over 200 man-hours on the car. Granted, much of this was spent on refurbishing / restoring / revitalising items which had never ever been cleaned prevously, or at least not cleaned to the level required for a Concours car. It can be stressful, with tasks sucking up time wherever any is available. Past participants often talk about how taxing it is to prepare a car, family and friends don't see much of you. All of this is true.
The financial outlay also cannot be ignored. Over and above any new or replacement parts purchased, the cost of chemicals and detailing equipment, and labour time, it all adds up. My goal was never to turn this car into a show-stopper, or make it sooo good that it rules out any meaningful use in the future (some participants only use their cars a handful of times per year, if that).
Was all the effort worth it? Based on my sentiments above, probably not. But this is like a disease, or like a drug. I was told last year that once this bug bites, you will be back. So here I am this year. There is also no financial prizes as such for Concours. So at the end of the day, it's doing it for the experience. What I also found myself doing is planning things for 2027 as well....
Was it satisfying? Oh yes. I am chuffed with all we have done, and do believe that we levelled up for 2026. Time would tell...
gavsadler
Update Oct-26 (cont.):
Sunday, 18-Oct-2026, D-Day had arrived. We woke up bright and early, and set off in convoy to Villa Arcadia (Hollard offices) in Houghton. We arrived, and were ushered to our respective spots - the 130i amongst fellow Concours entrants, and the M3 was parked on the lawns as part of the bigger display.
It seems like the postponed date did clash with some entrants dropping out, as well as a few last-minute no-shows. This also prompted a few last-minute entrants. Unfortunately time was against them, but I did offer them what I brought to the show to prepare their cars.
There were some epic cars on display, both in the Concours area, as well as on the lawns. I really enjoy seeing the hidden gems come out and about, and it was nice to listen to some stories from the owners of the various cars.
I'll share some pics I took on the day. The full gallery is available on the BMW CCG Race Series Website here: https://bmwraceseriesza.co.za/gallery/2026-bmw-car-club-gauteng-itoo-concours-delegance/
2025 class winners:
2025's overall winner:
It was a long day, kudos and thanks to the judges who spent hours in the sun scouring the cars, looking over every single little detail. We walked around, spoke to fellow members and enjoyed some good food.
Eventually it was time for the prize-giving, so we all congregated in the music room. After some opening words were shared, as well as thanking the sponsors and participants, it was time to start the awards. I'm quite chuffed to say that we won 1st place in the d'Elegance class (not 100% original / modified). Woo-hoo!
After the awards, we took a handful more photographs, before everyone started to depart and head home. It was another great day out, and I must say it's a good feeling knowing that all the hard work made a difference.
As I mentioned earlier, there are some things planned for 2027, and also on the day some small, but silly things were pointed out. It's quite funny how sometimes the most obvious things can be overlooked. But it's all part of the experience.
For those club and committee members reading this, thanks again for a great event, and it was a privelege to be part of it again.
And that pretty much wraps up the updates for the "Road to Concours" for 2026. Once again, thank you to all who played a role in some shape or form on this journey, my girls, Jabu, Peter, Yatish, friends and fellow enthusiasts. Special mention to my wife, for exercising some understanding and patience of this mad man! LOL
Something which also became quite apparent was how much I missed driving this car. I think for the 3 months leading up to Concours, it was only moved in and out of the garage, and maybe 1 or 2 trips through the suburb. It was really nice to stretch it's legs again.
Smiles all-round. Thanks for reading...
Nish_H
Great updates and well done on all the effort and work put in.
Congratulations on your award, from the pictures, effort and time spent, well-deserved.
I dont really understand it, but I really respect it... Well done on winning your class Gav, insane amount of effort put in with spectacular results
I find it really impressive that this car is "dished out" to family members for holidays etc then finds itself winning concourse a few months later 😅
I too do not understand it. But I also respect it.
Amazing stuff.
