help please 2010 bmw 335i xdrive N54 E92 im at a loss
NBN
I done that also, 850.00 dollars later for a new one. Sense installing the new one now my widows and mirrors operate opposite, my driver side works using the passenger side buttons and passenger side with driver side buttons. Any suggestions as to why, I have a feeling that new FRM needs to be programmed even though the dealership them self wanted my VIN# before selling it to me?
Doesn't mean it's coded to the vehicle... They merely ask for the Vin inorder to supply you with the correct part for your vehicle
2010e92-n54
You 100% need to code the new FRM properly to the car’s VIN and VO.
At the moment I'm between jobs, however after replacing both the crankshaft shaft position sensor and water pump saving on the labor by doing it my self, all the the codes I was getting are gone, every one except for a O2 sensor, thabks to everyone that was helpful in solving my issue's with the bimmer. Much appreciated, once I actually get it programmed is that going to solve the operation of the windows and mirrors operating in reverse? IE: drivers master switch, push the driver side window button and the passenger side window go down same with mirros!
