📩 The Enquiry
Recently, a forum member reached out to ask if we could assist with replacing the front brakes on his friend’s very clean, low-mileage, one owner 2017 BMW 640d. They had already ordered genuine BMW parts and wanted them meticulously fitted.
We agreed on a date, and in the morning the car was dropped off with:
🛡️ Preparation
As always, we began by adding protective covers to the driver’s seat, steering wheel, and footwell to keep everything spotless. The 640d was then moved onto the lift and the wheels removed.
🔧 Front Brake Service
🔍 Full Vehicle Inspection
With the brakes completed, we:
💻 Diagnostics & Final Checks
🚗 Collection & Feedback
Immediately after the car was collected. A follow-up a few hours later confirmed everything was 100% and that the owner was very happy with the overall service and care given to the vehicle.
Another happy BMW owner 🙌
- 🛞 New front discs
- 🛞 New front pads
- 🛞 New brake pad sensor
🛡️ Preparation
- Stripped the front brakes completely down to the hubs.
- Degreased and cleaned all hardware (calipers, brackets, retaining clips, bolts, etc.).
- Rust on the wheel hubs was removed with a wire wheel and cleaned up.
- Prepped the new pads with anti-squeal spray.
- Cleaned the new discs with brake cleaner.
- Carefully reassembled everything using anti-seize paste where required and medium thread-locker on bolts.
- Removed the undertray.
- Inspected suspension, engine, drivetrain, exhaust, rear brakes, and tyres.
Everything came back clean — exactly what we expected from a low-mileage car that’s been cared for since new 👌.
Reinstalled the undertrays and wheels before lowering the car.
- Ran diagnostics and generated an initial report with historical fault codes.
- Cleared all codes.
- Generated a final report showing 0 faults ✅.
- Took the car for a short road test to confirm the new brakes were performing perfectly.
