BMW E92 M3 – Minor Engine Service
Clint@MMS AUTO
I was recently contacted by Kev, the owner of a stunning BMW E92 M3, for its annual service. He had already purchased a few quality components ahead of time, including a new OEM BMW oil filter kit, a new Drain plug, a bottle of Liqui Moly Ceratec and 1 Liter of GT1 10w60, and requested we supply the remaining Liqui Moly Synthoil Race Tech GT1 10W60 as well as a can of Liqui Moly Injector Cleaner.
Once the oil arrived, Kev dropped off the car and we got to work.
🔧 Service Procedure
  • Fitted protective covers to the steering wheel and driver’s seat
  • Moved the vehicle onto the lift and began the service
  • Drained the engine oil from both sump plugs, allowing a full drain until no oil remained
  • While the oil was draining, we gave the undercarriage a full inspection checking the Tyres, Brakes, Suspension, Drivetrain, Exhaust, Differential. Etc
  • Replaced copper crush washers and refitted the sump plugs
  • Cleaned the drain plug area to avoid any residual mess
  • Lowered the car and removed the old oil filter, checking it for any metal particles or glitter – none were found
  • Extracted remaining oil from the oil filter housing, thoroughly cleaned the housing and cap
  • Installed the new OEM filter, pre-filled the housing with fresh oil, and torqued the cap to 25Nm
🛢️ Fluids & Additives
  • Added Liqui Moly Ceratec for added wear protection
  • Filled up with Liqui Moly GT1 10W60, one of the best oils available for the high-revving S65 V8
🧼 Airbox & Engine Bay
  • Removed the BMC performance air filter, cleaned it with compressed air to remove debris
  • Cleaned the airbox interior before reinstalling the filter and lid
  • Gave the engine bay a light detail, wiping down plastics and trim with a rejuvenating plastic dressing for a clean, OEM+ finish
💻 Diagnostics & CBS Reset
  • Removed the car from the lift and connected our diagnostic tool
  • Accessed the CBS system to reset the engine oil service interval
  • Ran a full system scan and found stored fault codes
  • Saved a full pre-service diagnostic report, cleared all codes, and verified that they cleared successfully (all historic faults)
  • Sent both the before/after diagnostic reports and all progress photos to Kev for his records
✅ Final Checks
  • Topped up the Windscreen washer bottle with Motul Vision Expert Ultra
  • Confirmed oil level was spot on
  • Performed a final visual check of the engine bay
  • Put the remaining engine oil bottle in a plastic bag and left it in the vehicle to be used in the next service.
  • Kev was extremely happy with the care, transparency, and attention to detail his M3 received — and we were honoured to work on such an iconic M car.
Thanks for reading – and stay tuned for more M-powered work!
1.jpg2.jpg3.jpg4.jpg5.jpg6.jpg7.jpg8.jpg9.jpg10.jpg11.jpg12.jpg13.jpg14.jpg15.jpg16.jpg17.jpg18.jpg19.jpg20.jpg21.jpg22.jpg23.jpg24.jpg25.jpg26.jpg
Clint@MMS AUTO
Apologies for the late replies, gents — daytime's for the grind, evenings are when I finally get to catch up!
Appreciate the kind words. I genuinely enjoy what I do, and I’m obsessive about keeping my workspace clean. Tools in place, floor mopped — everything spotless before the next car rolls in. That’s just how we do it here.
Clint@MMS AUTO
Thank you again @Clint@MMS AUTO for the stellar service and really being pedantic. This level of attention to detail and care, I have not experienced in any workshop before, its why I will continue to use and refer you to any enthusiast.
See you next month with the E46!
Thank you so much for the kind words and support 🙏🏼 It truly means a lot! we treat every car like it’s our own, and attention to detail is non-negotiable.
Can’t wait to have the E46 in next month, it’s always a pleasure working with enthusiasts who care about their cars as much as we do! 🔧🚘
