Hi all. So on Saturday I had an issue with my car that forced me to immediately stop the car when I got the drivetrain error. I won't go into detail on what happened on this post but for those who are interested you can read up on what happened here: https://www.babybmw.net/threads/m14...1/?post_id=1779369&nested_view=1#post-1779369
The guys at BMW Midrand updated me and told me that the engine is dead and I would need R380k to replace the entire motor. A bit much if you ask me but I undestand that figure as they are in the business of replacing not repairing.
However after some extensive research based on the report I got from BMW Midrand it seems like it could be a bad fuel injector which could have also potentially caused piston damage. Based on reading on other forums and groups, it seems like a common issue on 2016/2017 plate M140i's but it also seems like an issue that can be fixed by replacing the damaged piston and replacing the bad fuel injector.
At this point I'm just weighing my options on if whether I should get it repaired, forged or replaced. I wanted to find out if there's anyone you guys can recommend to do one of the jobs who is knowledgable on these B58 engines or at the very least modern BMW engines.
