Driving update
Car has been driven spiritedly after it got back from the workshop. No coolant issues.
The high fuel consumption is becoming a bit of pain though, with average sitting above 16 litres per 100km. I am not pushing the car that hard all the time. When I do push it, it approaches 19 litres per 100km for a trip.
The brakes perform well, though they need to be warmed up before they bite hard from a high speed. This can be an irritation when you want to take the car out for quick blast, since you need to remember to prep the brakes.
I am getting used to the hard suspension and the current Ohlins are set up for a good compromise between highway use and spirited back road driving.
Off-the-line performance is very good. With the car in sport mode, the supercharger kicks in and preps the car for maximum attack mode. However, at higher speeds the limitations of a 2.0 motor become evident. Even with 470Nm on tap, the muscle seems to drop off at higher speeds. At sane speeds, however, it feels stronger and more eager than (say) a German sedan of similar power.
The recent BMW skidpan experience was great and the car put up a decent time (I am no driving god), however understeer is still the name of the game with this car.
The steering is a bit lifeless when pushing on back roads - just like fast Audi cars.
I called up Motorite for a quote on a maintenance plan extension. They said that they do not cover the S60 Polestar for maintenance because it is too costly and risky for them. Well, that does not sound like a vote of confidence...
Anyway, I have the Volvo extended warranty for mechanical failures and a little maintenance fund for services and those expensive brakes (which I will consider replacing with Rotaras in the future maybe).
I do yearn a bit for more driver involvement at times. Like most modern AWD high performance cars, you need to drive fast to get proper thrills. My Cayman S gave those thrills at lower speeds, but had other limitations (like no rear seats and a harsh ride).
Let's see how this Polestar behaves itself in the coming year. If it has any major issues, a used (not abused) RWD 4 seater coupe may be on the horizon...
