Good day All!
My apologies if this topic has been covered before. I'm still having this persistant issue occur on my vehicle.
I have been experiencing a misfire that only occurs when my car comes to a stop during idle after reaching optimal temperature. If I come to a robot and stop for a while, the engine revs drop during idle and it hovers around 300 to 600, fluctuating. I would need to switch off the car and restart after 5 seconds. In most cases the misfire disappears, but then returns when I'm back at another robot waiting for the lights to turn green. This only happens during idle. During normal driving in town or on the freeway, there is no misfire.
I have done a full major service, new oil, new oil filter, new fuel filter, new spark plugs, new air filter.
I have replaced the MAF sensor and cleaned the idle control valve with carb cleaner and it operates freely without getting stuck, but still misfiring at idle.
I have check all the hoses and the air intake boots and there are no leaks. Still misfiring at idle.
The following codes were detected:
P0313
P1349-4 - fuel cut off
P1351-5 Misfire
P1345-2 Misfire
P1343-1 Misfire
P1353-6 Misfire
P1083 - Bank 1 Sensor
P1085 - Bank 2 Fuel Mixture too lean
P0313 - Misfire detected with low fuel
P0300 - random multiple misfire detected
I'm at a loss trying to figure out what it could be. I'm not sure if it is the coils, but then at normal driving speeds there is no misfire, no engine check light, nothing. Could it be the fuel pump? Not sure if it is that either. Could it be a problem with loss of compressing? Perhaps, given that the engine is doing 288k on the clock for a 2003 model. The rings could be a little worn.
Any help will be greatly appreciated.
P0313
P1351-5 Misfire
P1345-2 Misfire
P1343-1 Misfire
P1353-6 Misfire
