reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Four - The Engine Teardown Vanos Removed The dual mass flywheel wasn't in bad condition but LUK clutch and flywheel...
Today at 6:29 PM
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Three - Engine Removal Remove Intake, Exhaust Manifolds Remove the drive shaft bolts on the gearbox side from the flex disc...
Today at 6:28 PM
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Two: The Side Quest What really took care of the road for a week or so was a failed water pipe. I had changed the main radiator...
Today at 6:27 PM
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter One - Tools to remove the engine Bolt-on supports for the jack stands; these help secure into the factory jack spots and safely...
Today at 6:25 PM
T
TheFlash
reacted to
AdiS's post
in the thread
Found this 2003 e46 330i Individual
with
Like
The 6 speed and updated HVAC controls and some other updates came after the facelift, from production date 03/2003 onwards. I _think_...
Today at 6:25 PM
T
TheFlash
replied to the thread
I have a 2002 June E46 330i with a 5-speed MT. I think I have the same climate control as well; it's the first time I am seeing the...
Today at 6:24 PM
reacted to
TheFlash's post
in the thread
technical
with
Like
This is going to be a journey. Was originally intending to do some basic maintenance on my 2002 E46 330i. The original list - Sump...
Today at 6:24 PM
Sibonelo
reacted to
TheFlash's post
in the thread
technical
with
Like
Today at 6:06 PM
Peter@AEW
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Twelve - Engine and Gearbox Back In After giving the engine bay a good cleanup, the engine was dropped in with the gearbox...
Today at 5:53 PM
Peter@AEW
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Eleven - Engine Timing and Getting Final Items Wrapped Up The plan was to get everything close to lined up and finalise in the...
Today at 5:52 PM
T
TheFlash
reacted to
Clint@MMS AUTO's post
in the thread
with
Like
TODAY’S UPDATE - REAR SUSPENSION REFRESH In my attempt to constantly make some kind of progress on the car whenever I get a bit of...
Today at 5:15 PM
N
NBN
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Ten - Assembly Clocking rings and the separator for the oil ring. Unpack the wrapped block Unwrap the cleaned crank I...
Today at 5:06 PM
T
TheFlash
technical
Today at 4:37 PM
T
TheFlash
reacted to
Peter@AEW's post
in the thread
technical
with
Like
Bravo! Big End Bearing clearance is 0,030 to 0,070 typically so you are mid point which is excellent. Looks like a solid build!
Today at 4:15 PM
T
TheFlash
technical
Today at 4:15 PM
