R
raks16
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Six - Rings, Bearings, Oil Pump etc. Since the rings were the source of trouble since new, I was determined not to use the OE...
Today at 4:02 PM
R
raks16
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Four - The 5th Gear Lean This car came equipped with the five-speed manual ZF gearbox; at some point in my ownership of over 20...
Today at 4:00 PM
R
raks16
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Four - The Engine Teardown Vanos Removed The dual mass flywheel wasn't in bad condition but LUK clutch and flywheel...
Today at 3:59 PM
R
raks16
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter One - Tools to remove the engine Bolt-on supports for the jack stands; these help secure into the factory jack spots and safely...
Today at 3:56 PM
R
raks16
reacted to
TheFlash's post
in the thread
technical
with
Like
This is going to be a journey. Was originally intending to do some basic maintenance on my 2002 E46 330i. The original list - Sump...
Today at 3:56 PM
Peter@AEW
replied to the thread
technical
Bravo! Big End Bearing clearance is 0,030 to 0,070 typically so you are mid point which is excellent. Looks like a solid build!
Today at 3:36 PM
Peter@AEW
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Ten - Assembly Clocking rings and the separator for the oil ring. Unpack the wrapped block Unwrap the cleaned crank I...
Today at 3:34 PM
Peter@AEW
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Nine - Measuring Things Main bearings measuring right in between tolerances The big end measured fine as well...
Today at 3:31 PM
msm
reacted to
TheFlash's post
in the thread
technical
with
Like
Today at 3:29 PM
MLorgat
THIS IS MAKING ME WANNA DO MY SHOCKS NOW.
Today at 3:12 PM
MLorgat
reacted to
Clint@MMS AUTO's post
in the thread
with
Like
TODAY’S UPDATE - REAR SUSPENSION REFRESH In my attempt to constantly make some kind of progress on the car whenever I get a bit of...
Today at 3:10 PM
T
TheFlash
technical
Today at 2:33 PM
T
TheFlash
technical
Today at 2:04 PM
T
TheFlash
technical
Chapter Eight -The Cleanup and Cylinder Hone Start cleaning the crankshaft and oil squirters Once the varnish is removed, the crank...
Today at 1:53 PM
CK4LIFE
reacted to
in the thread
with
Like
Today at 12:56 PM
