I have an Dinan Cat back exhaust and need it installed by a pro.
There is not cutting / welding required it comes as a kit. Some of the existing mounts are reused.
The problem is that in order to remove the older ones some elements need to loosened etc. problem I am having is finding someone that will remove the required sections as per the documentation and ensure that it is done correctly including the correct torque settings for bolts etc.
Who can help that knows their stuff please ?
