The new BMW M2.(LCI)
Quick///M
Six-cylinder in-line engine with extra output and torque.
As well as the raw power itself, the inimitable way in which the six-cylinder in-line engine delivers that power also plays a key role in the performance experience offered by the new BMW M2. The upgraded version of the engine for the new edition of the high-performance sports car shines an even more vivid spotlight on the linear delivery of power, sustained into the higher reaches of the rev range, that is such a hallmark feature of M models. Its maximum torque is on tap across a wide rev band between 2,650 and 6,130 rpm. In examples of the new BMW M2 with the optional six-speed manual gearbox (fuel consumption, combined: 10.2 – 10.0 l/ 100 km [27.7 – 28.2 mpg imp]; CO2 emissions, combined: 231 – 226 g/km in the WLTP cycle, CO2 class: G), peak torque remains 550 Nm (405 lb-ft). And when power is channelled via the standard eight-speed M Steptronic transmission with Drivelogic, the figure rises to 600 Nm (442 lb-ft). The engine produces its increased maximum output of 353 kW/480 hp at 6,250 rpm, with revs topping out at 7,200 rpm.
So that drivers can explore the engine’s upgraded performance characteristics with an even greater degree of intensity, further advances have been made with the accelerator mapping and response in all the drive modes selectable via the M Setup menu. As a result, the new BMW M2 offers noticeably more rapid reactions to the driver’s requests for acceleration – both when specified with the eight-speed M Steptronic transmission and with the optional six-speed manual gearbox.
The ability of the new BMW M2 to offer further improved power delivery is rooted in an exceptionally strong technological base. Its 3.0-litre engine differs from the unit in the BMW M3/BMW M4 range in a few details only. The increased peak output figure of the new BMW M2 lends further weight to its leadership claims in the compact high-performance car segment. In addition, it now achieves parity with the manual variants of the new BMW M3 Sedan (fuel consumption, combined: 10.1 – 10.0 l/ 100 km [28.0 – 28.3 mpg imp]; CO2 emissions, combined: 230 – 227 g/km in the WLTP cycle, CO2 class: G) and new BMW M4 Coupé (fuel consumption, combined: 10.1 – 10.0 l/100 km [28.0 – 28.3 mpg imp]; CO2 emissions, combined: 230 – 226 g/km in the WLTP cycle, CO2 class: G).
Racing expertise delivers smile-inducing performance.
As well as its pair of mono-scroll turbochargers, an indirect intercooler and an electronically controlled wastegate, the M TwinPower Turbo technology of the straight-six engine also includes High Precision Injection, VALVETRONIC variable valve timing and Double-VANOS fully variable camshaft timing. The engine also has an array of details borrowed directly from racing car design and whose impact is most clearly evident in its lightning-fast response, appetite for revs and high performance capability in track use. These details include an extremely rigid crankcase with a sleeve-free, closed-deck construction, a forged crankshaft with lightweight design, cylinder bores with a wire-arc sprayed iron coating and a 3D-printed core for the cylinder head.
The M-specific cooling system ensures the powertrain components maintain an optimal operating temperature even under heavy loads. The oil circuit is also designed to handle extremely dynamic driving situations. A map-controlled oil pump ensures reliable oil supply even under extreme longitudinal and lateral acceleration.
The engine sends its drive power through an eight-speed M Steptronic transmission with Drivelogic as standard. The Drivelogic button integrated into the selector lever makes it possible to alter the transmission’s shift characteristics, with a choice of three clearly distinguishable settings. Both the selector lever in the latest M design and the gearshift paddles on the steering wheel enable sequential interventions in the gear selection process at any time.
Drivers keen to blend an intensely engaging performance experience with even more direct interaction with the powertrain can specify the six-speed manual gearbox as an option. This links up with the Gear Shift Assistant, which uses engagement speed control to ensure slip-free operation when downshifting under braking into corners.
Visually impactful exterior design with fresh accents.
Powerfully chiselled surfaces and athletic proportions mark out the pure-bred performance character of the new BMW M2, whose compact dimensions and wide tracks showcase it to visually dramatic effect.
M-specific design features geared to the functional requirements of cooling air routing and aerodynamic balance accentuate the eye-catching appearance of the two-door car. A large, horizontal BMW kidney grille and the three-section split lower air intake optimise cooling of the powertrain components and brakes.
The model-specific LED headlights are positioned towards the outer edges of the front end. In a tribute to the iconic BMW 02 models, they each have a single circular headlight that generates both low beam and high beam. U-shaped light guides at the lower edge of the headlights serve as both the daytime driving lights and turn indicators. Available as options are Adaptive LED Headlights with BMW Selective Beam non-dazzling High Beam Assistant and M lights Shadowline with dark inlays.
Significantly expanded range of exterior paint finishes; light-alloy wheels with a new design.
Customers can order their new BMW M2 in a choice of three solid colours, five metallic shades and six BMW Individual paint finishes. The significantly expanded range includes the new Sao Paulo Yellow solid, Fire Red metallic, Portimao Blue metallic and Skyscraper Grey metallic variants. Plus, the selection of BMW Individual paint finishes for the new BMW M2 now also features Java Green, Voodoo Blue, Grigio Telesto and Twilight Purple.
The new BMW M2 is fitted as standard with M light-alloy wheels in double-spoke design and with a Jet Black finish. Dimensions are 19 inches at the front axle and 20 inches at the rear axle. A new addition to the options list are M light-alloy wheels in double-spoke design and with the same dimensions, but finished in the colour Silver. They can be combined with track tyres if the optional M Race Track package is specified.
New steering wheels and seat surfaces, M Carbon bucket seats now also available as an individual option.
The most important interface between the driver and car – the steering wheel – has been newly designed, bringing a fresh look to the interior of the compact high-performance model. The standard-fitted M leather steering wheel of the new BMW M2 now has a flat-bottomed rim and precisely modified spokes. A red centre marker in the 12 o’clock position, gearshift paddles and the two M buttons for selecting individually configured vehicle setups project an intense racing car feel. An M Alcantara steering wheel is now also available as an option in the same design. A heating function is offered as an option for both steering wheel variants.
The optional M Sport seats in Vernasca leather can now also be ordered in a red/black bi-colour variant. Added to which, the weight-minimized M Carbon bucket seats for the new BMW M2 are not only available in conjunction with the M Race Track package, but now also as an individual option. With surfaces in Merino leather, multi-way electric adjustment, removable head restraints and a facility for adding a multi-point harness, they optimise both the car’s comfort levels and its racing credentials.
BMW Operating System 8.5, digital control for the climate functions.
The M-specific content in the BMW Curved Display and optional BMW Head-Up Display enhances the cockpit’s progressive sports car aura. The fully digital screen grouping, made up of a 12.3-inch information display and a 14.9-inch control display, now provides the stage for the latest evolution of the BMW iDrive control/operation system based on BMW Operating System 8.5. The functions of the climate control system are now also operated digitally. The temperature and ventilation settings as well as the seat heating and – if specified – steering wheel heating in the new BMW M2 can be controlled either by touch using a special menu option in the lower area of the control display or by voice command with the help of the BMW Intelligent Personal Assistant.
This broad adoption of digitalisation leads to a further reduction in the number of buttons and controls in the cockpit and is accompanied by a redesign of the instrument panel. New adjustment controls for the air vent grilles in the centre of the instrument panel and on the driver’s and front passenger side of the cockpit allow the airflow direction to be adjusted using rotating and tilting movements.
The interior trim elements in the instrument panel and centre console of the new BMW M2 come as standard in Dark Graphite matt. Interior trim elements in Aluminium Rhombicle Anthracite, M Carbon Fibre or new Fine Brushed Aluminium are available as an option.
P90553544_lowRes_the-new-bmw-m2-06-20.jpgP90553486_lowRes_der-neue-bmw-m2-06-2.jpgP90553485_lowRes_der-neue-bmw-m2-06-2.jpgP90553478_lowRes_der-neue-bmw-m2-06-2.jpgP90553476_lowRes_der-neue-bmw-m2-06-2.jpgP90553472_lowRes_der-neue-bmw-m2-06-2.jpgP90553320_lowRes_the-new-bmw-m2-06-20.jpgP90553307_lowRes_the-new-bmw-m2-06-20.jpgP90553306_lowRes_the-new-bmw-m2-06-20.jpg
TBP88
Nothing externally and I am sure nothing comes at a 50k increase
The steering is now flat bottom if that matters, it helps control the extra power they gave the car 🤣
Probably more than R50k...
I must say this is the one current BMW that continues to grow on me. I think in a wider set of colours it will be a cool car going forward.
