discussion New member - F22 220i M Sport
Nishcat_M140i
~R31k parts and labour
Ahh flip that's crazy bro.
But don't let that put you off driving the car though and enjoying it. Atleast it hasn't given any signs that its on its way out anytime soon. Its nice to get quotes here and there, atleast you can use BMWs price as a benchmark when shopping around.
Don't stress about it though, deal with that when and if the time comes because you never know, maybe you'll upgrade before its time to replace or maybe it won't give up.
When I was shopping for my daily, I came across loads of N20s for sale and as much as I was aware of the timing chain issue, the prices that they go for can be really appealing. I did research on this engine and what I found online is that the 2015+ models with the N20 got a new design making it less prone to the issues the earlier model faced.
From the looks of it, you might be safe in terms of the timing chain.
Urban963
Have you also gotten quotes from Ross Duncan and some other independent BMW specialists?
Not yet no, just went out in my lunch break. I did get a quote from Goldwagen - ~R8,000 for parts as opposed to BMW's ~R20,000.
Will get some comparatives this weekend, but looks like I won't be doing this now. I knew it's be costly, but crysis.
Urban963
Yea I still drive her and enjoy her when I do bro. Not too worried about the timing chain, just thought I'd get it done if I could. I didn't expect it to be quite that much, I don't have that sort of money lying around at the moment.
Thanks for the link, was a good read.
Urban963
Here's the quote. I see they've quoted VANOS Solenoid Valves as well. Anyone know if that's really necessary or are they just adding as many things as they can?
Urban963
Update:
Car ate the 4th serpentine belt on my way back from KZN. Luckily I was able to drive for around d another hour in the battery and make it to a Midas who had a spare. Grabbed the belt and the tensioner and replaced both. So that’ll hopefully be the end of that.
Then on Friday I notice my car making all sorts of fantastic turbo noises. Was driving with a semi for a while until it clicked that it isn’t supposed to be making excellent noises because it’s got recirculating, not venting to atmosphere.
Turns out the intake pipe broke. I've since replaced it with a new one. The car is also going in tomorrow to get the timing chain done so after that, just a few small things to button up and I'll be happy.
Urban963
Timing chain has been done and the engine sounds better now.
I also replaced the headlight washer nozzle. Nothing happens when I turn on the windshield washers though, so it seems the pump might be dead, though I need to get in there with a multi-meter.
Urban963
I replaced the windshield washer pump today and it now works like a beauty. Good times.
The headlight washed pump does not, so it's also faulty. Now to source one...
Progress is progress I suppose.
osiris
looks like everything is coming along nicely man! It's scary how such a "new" low mileage car needs a damn timing chain! FML!
But on the plus side, you should get a whole new life out of this car now!
Urban963
Thanks bro!
Yea the N20 just loves a timing chain, I figured rather do it now than after the valves sit at new and exciting angles.
I now just need to fix the A/C and replace the headlight washer pump and I can take a break from spending money, maybe.
If anyone wants to donate a front lip spoiler I'd be glad to give you a shout out to all my followers.
PS. I have no followers.
Urban963
Quick update and request for suggestions:
The car has been running well since the above service etc. It is, therefore, necessary that some other BS start.
On Sunday I did a spirited pull whilst turning right from a stand still and heard a strange rubbing/grinding type noise. I heard it from the passenger side. My passenger heard it from the driver's side. This, potentially, means it's from the middle?
I tried replicating the noise by doing pulls, brakes, turning, swerves etc. Only way to recreate is, reliably, is accelerating hard whilst turning right. Cant hear exactly where it's coming from but it's certainly happening.
Any ideas what might cause such a noise?
osiris
have you lowered suspension at all? sounds like car is squatting and then grinding, else it could be more mechanical like a wheel bearing or something.
Urban963
hey bru,
No, haven't touched suspension or anything. I thought of wheel bearing too, but it's only on a right turn under hard acceleration. I guess that would load the outer wheel, but not sure it accounts for it. My first thought was transmission but then I tested a bunch of things and couldn't find any fault or misbehaviour with it.
///Maniac
Check the handbrake cable bracket. Most likely that.
Urban963
Finally had a chance to get the car up in a lift as my stepfather’s new workshop is finally up and running.
Needless to say, this man knows what’s up.
Both brackets were broken, so the handbrake cables are rubbing against the driveshaft under harsh acceleration. They’re in a metal sleeve which is why it sounded like metal on metal.
Didn’t have any spare brackets obviously, so they’re just cable-tied in position for the time being until I get some replacement clips.
Other than that she still looks like a college student underneath. Check all bushings, seals, etc and the only thing that appears to need attention is the bump stops (completely toast) and some weeping at the gearbox 😐
Tsepz
This was one interesting read of a thread, enjoyed the humour and glad the car us running well, the F22s are absolute beauties, it does sound like the previous owner abused it and then got people who don’t know the car to work on it.
///Maniac
You're welcome. Pm'd you my banking detailsnin the mean time. 🤣
